HELP!! front brakes
Old Apr 3, 2005 | 12:34 PM
Matt_01SE_20th's Avatar
HELP!! front brakes
I just went to change my front brake pads, and found that i dont need to change them right now (well sorta). when i pulled the inside pad on both sides the center of the pad is not worn very much but the edges are worn alot more. i used a depth micrometer to measure the difference in the groove recesion between highest and lowest points and the difference is just over 1.5mm. my rotors are of course mirror images of this. I am just wondering if this is normal at all. i dont think it is. but i can see how it happens because the piston is larger than the padcreating an uneven pressure. i was thinking of getting new rotors anyway, so my second question is should i replace the pads now and hope for the best or just wait to get the slotted rotors and replace everything at once?
i cant get the pics in
i have them on my digital but cant import them. let me know how if you know.
Old Apr 3, 2005 | 12:51 PM
GBAUER's Avatar
I've never had it happen on mine. I have original rotors on my '03 (108k miles) and they (the pads) wear evenly. I think you may have an install problem. there's no way that the brake pad could cause a cup on the rotor the way your describing it.
(To post pics, go to www.cardomain.com and start your own site. Download there and go to FAQ section of the 5th gen forum for instructions on how to post)
Old Apr 3, 2005 | 09:12 PM
Kevin's Avatar
108k on stock rotors and no warping ? Either thats pretty good, or you're not much of a braker....
Old Apr 4, 2005 | 12:00 AM
nyautostyle's Avatar
anyone realize how much the nissan brake pads suck? I had to replace mine atleast 3 times already since i bought the car. running on about 53k miles
Old Apr 4, 2005 | 12:06 AM
SEmy2K2go's Avatar
Go BUCKS!!!
I've been pretty happy with the OEM pads. It's the rotors that are horrible. I'm currently running OEM pads with my iRotors slotted & cross-drilled rotors.
Old Apr 4, 2005 | 12:22 AM
how much did those run you? im just got stock rear rotors after 53k miles, but i was thinking of just switching all of them, not too sure whats good and whats not
Old Apr 4, 2005 | 12:24 AM
SEmy2K2go's Avatar
Go BUCKS!!!
The rotors were $300 for all four.
Old Apr 4, 2005 | 08:40 AM
bvenvert's Avatar
Brembo D/S and Axxis Ceramic Pads
I replaced my brakes about a year ago and got away from the OEM rotors and pads. I put Brembo D/S rotors and Axxis Ultimate Ceramic pads and haven't looked back. I have put about 25K miles on them and they work great. Smooth braking and little or no fade. My cars stops great. Ceramic pads produce much less dust and the rotors don't wear out near as quick. I will never go back to stock.
AcuraLegend
Oct 17, 2016 08:47 PM
AcuraLegend
Sep 22, 2015 04:22 PM
homeyclaus
Sep 3, 2015 06:15 PM
A32goldylocks
Sep 2, 2015 06:39 AM
MAXSE5SPD
Aug 23, 2015 12:06 PM
