Best way to turn the key...
Stupid question but...I've found my car starts better if I briefly stop the key at "On" before turning it all the way to ignition. Am I hallucinating or is there something legit going on here?
when you turn the key to "on" it activates the fuel pump....so if you pause there, it gives the fuel pump time to pressurize the system, hence why the car starts better when you pause there.....
Originally Posted by TXT-1
Aww man, I read the title of this thread and was all ready to come in here and flame away. But then a learned something new. What's up with that?
http://forums.maxima.org/showthread.php?t=394102
What irish44j said is true. I heard a guy that was a chief engineer from GM say that on tv. He was an expect in cold weather conditions and said to always pause at the "on" position for a few seconds before you turn the key all the way.
Starting/cranking?
May not be related to what everyone is talking about but at times when vehicle started cranks twice and stops have to turn key off and then starts right up. Any ideas, has been at dealer for update on computer several times but still having hard start issues. Thanks for any replies.
Originally Posted by ihavea5spd
Guess I'll try the advice in this thread. Maybe my car will start up on the first fire when I leave it for about a few hours.
Originally Posted by PaulyPoTz
do u guys sit there and wait for every beep?
http://www.englishclub.com/
another tip for you people w/o gas:
2000 max gxe
If the engine will not start due to no gas, park the car on a hill with the nose pointed down. The precious little gas you have will run to the front/bottem of the tank where it can get to the engine
This might be different for other cars
2000 max gxe
2000 max gxe
2000 max gxe
I agree...I try to just start it really quick and the engine revs really high and makes a high-pitched whine. However, when I know the car is already warm it starts fine. Interesting, I must say.
Yes, there is crap on the bottom of the gas tank and can cause engine stall. Be careful when running on gas at the very bottom...
tarun900
19
Dec 20, 2021 06:57 PM
RealityCheck
Oct 2, 2015 06:34 PM
