HID conversion or Xenon suggestions
Old Apr 5, 2005 | 11:08 PM
bamasae's Avatar
I was thinking about a HID conversion for my 2000 SE, but they are a bit pricey. Has anyone used one that they can recommend and is it worth the $$$. How hard is it to install?
Outside of HID, any brands of Xenon that give a good comparable look?
I'm really just looking for something that gives it a light look similar to the later Maximas without having to spend a fortune.
Any help would be appreciated,
-Mike
Old Apr 5, 2005 | 11:15 PM
Larrio's Avatar
The Definitive AE Master
Here is what I have:
2002-2003 OEM Nissan matsushi.ta ballast, harness, and starter ($115)
www.ebay.com
Casper's Electronics H4 hid shield ($50)
here
Global Premier H4 power connector ($12)
here
D2S bulbs (free from friend)
Total: $177
Only down side is that I do not have high beams
Old Apr 5, 2005 | 11:22 PM
danimsta's Avatar
2k2-2k3 HIDS
save up ur 6-800 bucks and get these
then get the wiring harness from a nissan dealership or at courtesyparts.com
u will also need 2k2-2k3 headlight clips (about 5-10 dollars)
then install
then save up again and get angel eyes and clear ur blinker
then get hid fogs..
o wait, thats what i did
Old Apr 5, 2005 | 11:53 PM
Talyan03's Avatar
im selling custom 00-03 HID headlights check ebay if you are intrested. they are black and the reflector is cleared out
Old Apr 6, 2005 | 01:30 AM
panda_1's Avatar
i bought...
a set of new denso ballasts $210 shipped
h4 HID Adaptor $43 shipped
set of 4300k bulbs $40 shipped
worth not having the high beam, its not required the hid owns it.
Old Apr 6, 2005 | 01:36 AM
danimsta's Avatar
hey 305, what did u use to paint ur rims?
looks very nice
Old Apr 6, 2005 | 05:38 AM
ZIPPIN's Avatar
Mauja He Mauja
looks very nice
try PAINT
Old Apr 6, 2005 | 05:41 AM
BudVlad's Avatar
Befor you get HID go to hidplanet.com/forum and read “Think again before getting a HID kit”
Old Apr 6, 2005 | 05:57 AM
NismoMaxm's Avatar
And if you do decide on buying a HID kit you would be better of just buying the OEM 2k2 or 2k3 headlights. Ive heard from many many guys on the org that its the way to go. That way youll jsut have to install the headlamp and the HID will already be in place.
Old Apr 6, 2005 | 09:45 AM
Dr. Roy's Avatar
Figure I will throw in my $0.02. On a HID retrofit.:
This option is somewhere in the middle of those mentioned above...About $150.00 more than a
H4 HID kit but about $150. less than 2K2-3 HIDs. But this rout will provide the best light output, beam
pattern and cutoff sharpness/color. The aesthetics of the projector headlights have been argued both
ways and a is a matter of personal taste.
$250.00-Aftermarket projector headlights new- eBay
$ 60.00 -04 MDX Acura headlights used- eBay
$100.00-matsushi.ta ballasts (unlabeled) new- eBay
$ 55.00 -Phillips 5000K D2S hid capsules used- eBay
$ 15.00 - odds and ends for retrofit home depot
$ 9.00 - 21K mcd LEDs (optional Halo upgrade) new-eBay
$ 0.00 - MDX projector retrofit/LED write-up my homepage
+ $ 0.00 - 3-5hrs & some elbow grease you
$489.00 (give or take)
you may be able to find used headlight for under $200- I. you would be lucky to find the that price on new ballasts,(I was). The MDX projectors are halogen but work great w/ D2S HID bulbs, and come w/ a gasket & bezel used in the retrofit. But another $30-40 will get you a (better??) set of real HID projectors. The ease, small cost and large improvement: mandate the LEDS get swapped while the headlights are apart.
Old Apr 6, 2005 | 01:34 PM
bamasae's Avatar
I appreciate all of the input guys...lot of options here.
If I decide to retrofit the 2000 with a set of 02 or 03s, will they just slide in there? Everything is the same shape and size?
Old Apr 6, 2005 | 01:40 PM
beer20's Avatar
this is the route im going,cant wait.
excellent write up by dr roy too.
[QUOTE=Dr. Roy]Figure I will throw in my $0.02. On a HID retrofit.:
Old Apr 6, 2005 | 03:53 PM
Dr. Roy's Avatar
thanks, but the how-to actualy needs to be updated, after i wrote it i found a better way to mod and mount the MDX projector, that solved some small issues w/ the retro and gets more color from the projector.
If you search for "MDX projector" on hidplanet.net you should be able to find the a thread or two by me, w/ pics of the what was done differently.
Old Apr 6, 2005 | 04:41 PM
beer20's Avatar
are you refering to the spacers you used to make the bulb a little further back?
you think you might update that writeup ?
if not im sure i can figure it out between the write up and your posts about it on hidplanet.im probably not doing it until next month anyway,but thanx....
Old Apr 7, 2005 | 06:20 PM
Dr. Roy's Avatar
writeup has been updated
Old Apr 7, 2005 | 06:44 PM
lalaMAX's Avatar
well looks like mine are the cheapest..... CDN$325 for a hi/lo kit.... but u have to aim properly if not people flashing their hi beam all over the place....... coz it can blind people..... u want quality get the 02-03 OEM.... u wait kinda middle... do retro.....
mine are the cheapest..... u can go to my home page and check it out
gigabyte
Jan 6, 2017 06:05 PM
maxinout93
Oct 31, 2015 02:04 AM
Calabar
Oct 5, 2015 09:57 PM
Cipitiox
Wheels/Tires
Sep 30, 2015 06:16 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
