HELP!!!! car broke down
Old Apr 11, 2005 | 06:41 PM
maximillus's Avatar
so i was driving home and i floored it. once it hit 5 rpm's i heard a loud "thump/cunk" noise and then the car just shut off. wat could be wrong? i am thinking that it is a blown maf? maybe the timing belt? and the only mod i have is an intake
Old Apr 11, 2005 | 06:51 PM
BlackBIRDVQ's Avatar
drag racing is for wussies
will it restart ? try UNPLUGING the MAF, does it start now ? if neighter one does the trick, maybe your throttle body took a dump, or something like maybe your camshaft position sensor went bad ? Try the MAF- unplug it, if the car runs but won't go over 2400RPM, you need a new MAF, its 500 bux new.
Old Apr 11, 2005 | 06:58 PM
maximillus's Avatar
the car is not at home but i will try that once i leave the house...any other things that i can try?
and when i try to turn the car back on...it turns on but once i turn it on the rpms start to die down and then goes to 0
Old Apr 11, 2005 | 07:05 PM
NismoMaxm's Avatar
sounds like MAF, i once read in a forum that a blown MAF, when the gas is put on the car wil die down in rpms and shut off. i could be wrong though!
Old Apr 11, 2005 | 07:08 PM
I blew 5 MAFs myself, on the 6th one now- I think I know what a bad MAF does. Unplug it, see if its going to run any better. It should run but not allow you to go more than 15% throttle or past 2400RPM. ECU goes into limp home mode. I once drove home from Chicago- 25 miles on I90 doing exacly 2350 all the way home- which is 59MPH. Longest drive home ever for me, I got a new MAF and was good to go, now I carry one with me in case.
Old Apr 11, 2005 | 07:09 PM
maximillus's Avatar
gosh i hope its not the MAF...pleeeeeeeeease
maximillus's Avatar
oh wow...isn't a MAF 500 bucks to replace? were u under warranty?
Old Apr 11, 2005 | 07:10 PM
NismoMaxm's Avatar
yeah 450 dollars or so.
Old Apr 11, 2005 | 07:12 PM
maximillus's Avatar
dayam blackbird u must be a balla. how long should i leave the maf sensor unplugged for?
oh yea and why does the maf go bad?
Old Apr 11, 2005 | 07:16 PM
Stardust's Avatar
F---ing Kangaroos
5.0 gen MAF's are ~$90
5.5 gen MAF's are ~$450
Old Apr 11, 2005 | 07:18 PM
maximillus's Avatar
wow why is the price difference so high?
Old Apr 11, 2005 | 07:20 PM
MAF sensor is flimsy, the hot wire breaks off inside the sensor- there are 2 of them. Once one goes the vehicle behaves very weird, and will not wanna run good. All the other cases come from high resistance inside the MAF due to oil or what not that contaminated the hot wire itself. VW/Audi MAFs are even worse than ours. I recall paying like 46 bux for the MAF element itself, or 76 bux for the whole assembly. 3.0L MAFs are dime a dozzen
Old Apr 11, 2005 | 07:23 PM
Stardust's Avatar
F---ing Kangaroos
We're not talking about your cost for MAF's.
Old Apr 11, 2005 | 07:27 PM
maximillus's Avatar
i think this is the first time i wish i had a 5th gen rather then a 5.5 gen. i was trying to save up for struts and was just about there.
Old Apr 11, 2005 | 07:28 PM
Beat it, you are runing on my custom MAF
Old Apr 11, 2005 | 07:33 PM
maximillus's Avatar
haha....i just hope that unplugging it will work...pray for me...
Old Apr 11, 2005 | 08:23 PM
Stardust's Avatar
F---ing Kangaroos
Old Apr 11, 2005 | 08:39 PM
Why don't we settle this on the DYNO ? :grino:
Old Apr 11, 2005 | 11:36 PM
maximillus's Avatar
thanks blackbird for the advice to unplug. i did it and was able to get my car home. now i gotta take it to the stealer.
Old Apr 12, 2005 | 06:15 AM
Mizike's Avatar
have you read the thread about modifying a 3.0L MAF for around $100, saving $400?...check the past few days, I know I saw it in there.
Old Apr 13, 2005 | 10:09 PM
maximillus's Avatar
what should i do about my intake when i take it to the dealership. i believe i'm under warranty until 75k miles or 6 years. is sumthing like this not usually under warranty or do i need to put the stock one back on before i take it back?
Old Apr 14, 2005 | 07:08 AM
Puppetmaster's Avatar
You can use the 00-01 MAF in an 02-03... it will trip a CEL but will work fine. If you want to get rid of the CEL and do it right, you'll need to transfer the IAT sensor from the 02-03 MAF over to the 00-01 MAF. Details are in the thread, along with pics and part numbers.
http://forums.maxima.org/showthread....ght=thermistor
maximillus, if money is a concern, just do this. You can get a MAF from DaveB for $90.... his phone number is in the FAQs... everyone here uses him to get OEM parts....
Old Apr 14, 2005 | 08:40 AM
maximillus's Avatar
is wat goes bad the maf, the maf sensor, or both? if its just the maf i'm thinking i don't need to take it to the dealer and just buy the maf from somewhere either if i do the 02 maf or the 00-01 maf.
Old Apr 14, 2005 | 09:07 AM
I'm not sure I understand what ya mean here... the MAF is a sensor... there is the MAF housing, the MAF sensor, and the IAT thermistor, if that's what you're confused about. The MAF sensor goes bad, but you can keep and reuse the housing and the IAT thermistor (unless you buy an 02-03 MAF, which already has an IAT thermistor/sensor).
Old Apr 14, 2005 | 03:22 PM
maximillus's Avatar
oh ok...thanks for clearing that up. is the sensor something that i can change or should i leave that to the dealer?
Old Apr 14, 2005 | 05:03 PM
You can definitely do it yourself....
MikesChevelle
Nov 23, 2024 11:17 AM
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
Balkins
Aug 12, 2015 06:39 AM
bassmann
Aug 3, 2015 07:53 PM
