Car stopped for 7 weeks, problem.
Old Apr 13, 2005 | 04:28 AM
GuZo's Avatar
I was away on vacation and I left the car in my garage. Before I left for vacation the battery had drained a couple of times and I had to get jumped.
While I was away my dad would go every 4 or 5 days to just turn the car on. He said he went one time and the battery was dead, since it was already 3 years old he had his mechanic go to my garage and put a battery in, but because of my aftermarket alarm going off they left one of the terminals disconnected.
Yesterday I got back and we connected the terminal. First the car started but died immediately after. Then I started it and revved it a bit and it was fine. Than while driving the idle would go real low to about 500 and the car actually died once. After drivin around a bit it got better but it's still idling a bit low.
Anyone know what could be the cause of this?
Old Apr 13, 2005 | 07:00 AM
Maxima-Ness's Avatar
moisture in the gas tank? maybe?
Old Apr 13, 2005 | 10:32 AM
GuZo's Avatar
My dad thought that too. Now everytime i start the car if i don't rev it a bit it dies. If I rev it it stays fine but with an idle at around 600.
Old Apr 13, 2005 | 10:43 AM
PoLo's Avatar
2-Wheelin it...
ever consider just doing a general reset. or maybe throwing some cleaner into the car to give it that extre pep. i would start off with a general ECU reset. and fyi, if it was an DEI alarm (viper, etc..) you can disable the alarm by opening the driver side door and pressing arm, disarm, arm, and it goes into valet mode.
Old Apr 13, 2005 | 12:26 PM
ThunderMaxi's Avatar
Throw some Sea Foam in the tank to reliven stuff up. After sitting idle parts dry up and it takes a little cleaning to get them good to go!
Old Apr 13, 2005 | 12:46 PM
GBAUER's Avatar
I'd seafoam the gas and oil and use the last third in the intake (vacuum hose). It'll stabilize the gas and oil taking the water out and clean up the gunk in the intake. Should solve the problem. (FYI: I had the same until I used Seafoam)
Old Apr 13, 2005 | 01:19 PM
CCS2k1Max's Avatar
How many miles have you put on it since? I am guessing that the ECU needs to "relearn" everything since the battery was disconnected for so long (A/F ratios, idle, throttle position, etc.). I say keep driving her and see.
Old Apr 13, 2005 | 02:37 PM
GuZo's Avatar
So far I have driven it about 60 miles. The only problem now is that it shuts off right after I start it, when the engine temperature is normal. If i rev it when starting it will stay on but the idle will still be low.
If the car is cold, it starts and stays on.
Where can I find this Seafoam product, and what is its function?
Just put the Seafoam in the gastank?
Old Apr 15, 2005 | 07:54 AM
GuZo's Avatar
Problem solved, went to dealer, all it needed was an idle adjustment.
Old Apr 15, 2005 | 02:54 PM
MaximaPolak's Avatar
A dealer actually did something for your car? Which dealer?
Old Apr 15, 2005 | 06:55 PM
GuZo's Avatar
pm me.
10 chars
Lakersallday24
Nov 7, 2024 07:31 PM
Lakersallday24
Jun 16, 2019 01:35 AM
egali045
Aug 16, 2015 01:19 PM
doobadoo
Aug 15, 2015 06:43 PM
yat70458
Aug 3, 2015 01:16 PM
