wheel spacer and stock 2001 wheels
Old Apr 14, 2005 | 07:49 AM
ao3dave1994's Avatar
Looking to put a spacer in the back to push the wheel more even with the front, any suggestions, comments, best places to get and best prices....also looking to lower the car, do not want it in the weeds mainly just level the front with the rear as the front looks alot higher, I want an adult ,classy ,BMW 330I look that can go in the car wash and take rough roads without bouncing me through the sun roof...any suggestions greatly appreciated.
Old Apr 14, 2005 | 09:32 AM
MrPoisse's Avatar
here some info I found on the org for wheel spacers
http://home.insightbb.com/~davidwhon...cer/spacer.htm
In your opinion, what are the pros and cons for wheel spacer?
Heres what I thought off, add or correct the list please:
PROS:
- look (wheels even with fender)
- handling (wider stance)
- other?
CONS:
- harder on mechanic?
- less thread on studs if you keep the same studs
- what else?
Im thinking about getting wheel spacers but wondering if theres drawbacks to it.
thanks!
Old Apr 14, 2005 | 11:45 AM
Max_Vader_2K's Avatar
I am looking to get some too but I forgot what size to get either 20mm or 25mm or 30mm? can anyone help?
Old Apr 14, 2005 | 01:12 PM
NewLoveI30's Avatar
I got the 15mm H&R spacers a while back, although I think you can go with 20 or even 25mm. I think it looks great, but I didnt notice any difference in handeling though.
The H&R kit is really nice. The spacers are hubcentric and the longer studs, which are needed, come provided. They are light weight and look really good. It's a shame they have to go behind the wheel. lol.
Forgot where I got them tho... It was a long time ago.
Old Apr 14, 2005 | 01:18 PM
spiromax's Avatar
Seoul Man
The size you get depends on what you're trying to do. If you're just trying to get your stock rear wheels to push out a little more so they look even, 20mm spacers are nice. If you happen to have aftermarket wheels with a weird offset, then the spacers you choose will depend on the offset of your wheels.
Old Apr 14, 2005 | 01:19 PM
NewLoveI30's Avatar
For the suspension you should probably go with the H&R's too. They have a nice level drop and Ive heard that the ride is pretty good. I have the Eibachs so I dont have any experience with the H&Rs. The Eibach pro kit is great, but be prepared for a good stiff ride though.
For struts I went with the Tokico Illumina adjustable dampers. These things are awesome! They keep any bouncing under control and make for super handeling. I got mine for around $400 or so from www.southwestautoworks.com
Old Apr 14, 2005 | 01:23 PM
I found a site that has the stubs installed on the spacer itself, with no need to remove the old stubs. very simple install. I will post the site alittle later if no one beats me to it.
Old Apr 14, 2005 | 01:24 PM
nyautostyle's Avatar
how could u tell if they are hubcentric or do all of them come this way?
Old Apr 14, 2005 | 01:30 PM
http://www.optionimports.com/kiprwhsp.html
Here is the link I need to know if 30mm will fit on the back?
Old Apr 15, 2005 | 04:33 AM
Fezzik's Avatar
30mm i think is too much, but I dont really know. I have not seen an org memeber put 30mm on or even if they make 30mm for our car.
Old Apr 15, 2005 | 04:51 AM
ZIPPIN's Avatar
Mauja He Mauja
20mm is what most ppl have here. good luck finding the H&R's. they are always on back order.
Old Apr 15, 2005 | 07:21 AM
Does anyone have a pick of there car with the spacers and the H&R springs, I just do not want to go to low, I want it to look like the way it should have come from the factory, sleek ,cool, and just right without going to far. Thanks for all the helpful info.
Old Apr 15, 2005 | 06:04 PM
MrPoisse's Avatar
as I said...
Old Apr 15, 2005 | 10:59 PM
noahrexion's Avatar
Ya you don't necessarily need the H/R, though they are nice quality.
This place here has really quality spacers IMO. They are "KYO" and Ive had 2 sets on my s13 and s14 and they worked out great. No need to wack out studs, these go rightonto your wheel and come with hubcentric rings for each application. I had no vibrations at all and was always swapping wheels for track/street in my 240. This is a really old pic when i first got them, but you get the point with a bolt on spacer. I think 15mm is the smallest bolt on size you can get with these, I like them because they match quality with all others and are by far the cheapest...
Old Apr 15, 2005 | 11:36 PM
spiromax's Avatar
Seoul Man
I found wheel spacers on that site, but they all came with new studs in 20mm. Do you know something we don't?
Old Apr 15, 2005 | 11:56 PM
A'sMax's Avatar
i'm using 20mm now and got 25mm set for sale, it isn't H&R
Old Apr 16, 2005 | 12:00 AM
panda_1's Avatar
im putting a 25 mm set of h&r's on the back, and a 15 (i think) on the front.
Old Apr 16, 2005 | 12:58 AM
noahrexion's Avatar
[QUOTE]I found wheel spacers on that site, but they all came with new studs in 20mm. Do you know something we don't?[QUOTE]
Ya sorry I accidentally said 15mm was the size, I meant 25mm is the smallest size bolt on they have. My apologies.
Old Apr 18, 2005 | 07:18 AM
MrPoisse's Avatar
Old Apr 18, 2005 | 09:44 AM
Yeah , I want to stay with stock wheels and tires, what is the best for looks without any hassles, is it really recommended for the front?
Old Apr 18, 2005 | 09:54 AM
ChromeSE5's Avatar
you 240 guys and wheel spacers. jk My friend has some spacers on his 240sx also except he has 1 1/2 inch spacers since his r32 wheels do not come flush with his fenders. Do you know if the s14 dust cap and maxima dust cap are the same size?
Old Apr 18, 2005 | 10:00 AM
maximized2
I have 15mm spacers on and you can barely see the difference, also I have kyb gr2's and tein s-tech way too low and rough. The reason you can't go any wider with the wheel spacers was stated earlier, not enough threads.
Old Apr 18, 2005 | 10:01 AM
maximized2
I only put spacers on the rear!!
Old Apr 18, 2005 | 10:06 AM
spiromax's Avatar
Seoul Man
Yeah, 15mm spacers may not push out far enough. 20mm spacers don't really push the wheels out noticeably; they just get rid of the weird recessed look of the rear wheels, and they make the car look like the way it was supposed to look in the first place. If you go with 20mm or wider spacers, you'll need longer studs to replace the stock ones, or else there won't be enough thread to secure the wheels on.
Old Apr 27, 2005 | 10:55 AM
Then I "might" just be the one to get the 30mm spacers on the back and 25mm up front.
Old Apr 27, 2005 | 01:17 PM
I saw the 25mm on ebay new from some company for only like $89 and shipping. Just fyi. Keep posting the pics, always greast to see different combos to get ideas about what some of us would like as far as looks. THanks
Old Apr 27, 2005 | 04:15 PM
sublimer's Avatar
the H&R spacers already come with longer studs, so the 20mm size shouldnt be a problem. I'm thinking about getting them myself....
Old Apr 27, 2005 | 04:25 PM
NISMAX03's Avatar
I had H&R 15 mm spacers up front and H&R 20 mm spacers at the rear with the stock TE rims (45 offset) and 235/45-17 tires. Both set of spacers came with longer bolts and the tires were flush with the car. I also have Maxspeed springs which give a slight drop without a harsh ride and no rubbing. I purchased the spacers from here.
Old Apr 28, 2005 | 09:05 AM
thats tight, i like that look, I wanted to keep stock rims to keep the factory look, I just want to make it look better. I like the look alot of the spacers and your drop, are you using stock shocks?
Old Apr 28, 2005 | 11:08 AM
S00NR1's Avatar
OU > *
The widest KYO spacer I see on that link is 10mm....am I missing something?
Old Apr 28, 2005 | 12:17 PM
I just looked at these on ebay and they look pretty good.
Old Apr 28, 2005 | 12:24 PM
NISMAX03's Avatar
I now have the G35C rims (30 offset) with 235/40-18 tires that you see in my sig. I am still using the stock shocks but will be purchasing Iluminas soon.
Old Apr 28, 2005 | 12:40 PM
screamindman's Avatar
Don't wheel spacers put unnecessary stress on the wheel bearings? If you don't want your car so low that it is terrible, then go with the Eibach pro-kit. It is firm, but controlled. I like the stiffness of them, it makes the car feel like a tank in terms of solidity.
Old Apr 28, 2005 | 07:28 PM
fornimage's Avatar
Let me see if I get this right. When you guys say that the spacer kits from H&R come with longer studs, do you mean that the studs come preattached to the spacer or do the studs have to be pressed into the existing hub?
Old Apr 28, 2005 | 08:41 PM
BEJAY1's Avatar
Conecarver
H&R type need to be pressed into existing where they replace the original bolts.
The Frye
Sep 2, 2021 11:03 AM
TheMafia
Sep 4, 2015 08:26 AM
maximusrising
Sep 2, 2015 09:55 AM
coasterswim
Sep 2, 2015 07:43 AM
Lowered_a33
Sep 1, 2015 07:49 PM
