brake light out...can't fix it
Old Apr 15, 2005 | 01:49 PM
2k2nyc's Avatar
My brake light is out.....tried replacing the bulb but had not luck...am i missing something or am i having an electrical problem?
PS - Other than the brake light, my tail light is fully functional.
Old Apr 15, 2005 | 02:10 PM
NYPD-Arnold's Avatar
Z
Your harness is shot. You're gonna' need a new one. Common issue.
Old Apr 15, 2005 | 02:21 PM
2k2nyc's Avatar
Is it expensive? DIY job?
Old Apr 15, 2005 | 02:28 PM
SoonerFan's Avatar
Cletus
might just be a bad connection in the socket
check the metal tabs that the bulbs touches. mine used to do that and when i moved the bulb around it would work. i had to bend the tabs out more and it fixed it
Old Apr 15, 2005 | 03:18 PM
Z
It's pretty darn easy. All you do is slide out the old harness and slide in the new one and pop all the bulbs into the new one's sockets. You can also try and see if jiggling the bulb does anything. If that works, then you may need to take Soonerfan's advice.
tsi6001
Oct 3, 2022 10:23 PM
JMag90
Aug 25, 2015 09:17 AM
Nismo_Guy89
Aug 24, 2015 09:49 PM
Samedi
Aug 13, 2015 04:05 PM
