Stillen RSB.....
Old 04-15-2005 | 09:36 PM
Bl_asd's Avatar
Stillen RSB.....
hi, I got my stillen rear sway bar.. the links for installation above doesn't work..can anyone tell me how to put them on and where to put them on without rubbing the brake lines...
Old 04-15-2005 | 09:38 PM
irish44j's Avatar
retired moderator
they didn't come with instructions? Mind did
anyhow, the blue brackets (obviously) go around the trailing arm....there should be a spacer to space out the brake line bracket (or was it the ABS bracket).....hmm....so long ago, I really don't remember - but it was very easy.
just email Stillen and ask them to send/fax/email you the instructions
Old 04-15-2005 | 09:41 PM
Bl_asd's Avatar
i bought them used....so no instructions.. the blue brace things have wears and tears on them too..sigh... btw..long time no see guys.. recntly have squeeking problems with my car.. and this rsb has been sitting in my trunk for half year now..
Old 04-15-2005 | 09:42 PM
Lontar1's Avatar
Puerto Rico-Maxima Lover
here you go.. follow it.... good How to...
http://vqpower.tripod.com/rsb.htm
Old 04-15-2005 | 09:46 PM
Bl_asd's Avatar
THX guys
Old 04-15-2005 | 09:49 PM
Bl_asd's Avatar
hmm 1 more question, it says
"Remove the bolt for the emergency brake line. You will reattach this with an adapter piece (already installed in picture below) and new "
what's the adapter piece?
Old 04-15-2005 | 09:52 PM
irish44j's Avatar
retired moderator
Bl asd...make sure you have the small spacers for the ABS line....if you don't, you'll have to go to home depot and find something similar that will work...
the adaptor is just a small aluminum tube and a longer bolt. you can see it in the pictures, as it holds the line out far enough to clear the brackets.
Old 04-15-2005 | 09:55 PM
Lontar1's Avatar
Hey you are in Orlando..PM me and I might help you with your install....
Old 04-15-2005 | 11:00 PM
ChromeSE5's Avatar
i think you will enjoy having the rsb on...i just went canyon running with my friends after i installled it and all i can say is WOW.
Old 06-01-2005 | 09:33 AM
2k2MerlotSE's Avatar
JUVIN's ride
Hey guys,
I had mine installed by Enjucking racing in Orlando. I was looking over the pics and realized they F&*cked up. First off they did not use the 3rd and 5th wholes. Second they did not face the bolt away from the brake line and I just notice they removed the bolts instead of aligning the bracket in between them.On the driver side facing the bracket, the bolts on the bottom left does not go all the way through the nut.
I think these guys messed up big.
Do I need new hardware if I wanted to remove it and reinstall it right?
what problems, besides the brake line can I have?
thanks
Old 06-01-2005 | 09:47 AM
CCS2k1Max's Avatar
The spacer is shown is this page http://www.greghome.com/Greg's%20Gar...StillenRSB.htm
I need to go back and redo the spacer on mine as I bough the rsb used and didn't get the spacer. I went to True Value and bought some brass spacers that should do the trick, but need to get the longer M6 bolts.
Old 06-01-2005 | 11:26 AM
JUVIN's ride
I just realized what they did. They removed the ABS bolts and bracket. Now I have to go back up there to get it back and install it right. damn!!!
Fbana41
08-29-2016 01:18 PM
05RLS2
04-14-2016 12:49 PM
Nv2dmaxmd
10-19-2015 06:37 PM
Stagnet04
09-15-2015 12:28 AM
Quick Reply: Stillen RSB.....
