aqueeky brakes
Old Apr 17, 2005 | 11:29 AM
jeepik's Avatar
aqueeky brakes
Ok i put new Brembo Slotted/Drilled rotors front and rear
with Axis ultimates pads front and rear on yesterday
i get a little squeek when i apply the brake pedal from 40mph and slower
when i slam on the brakes it works great no squeeks
also at low speeds it doesnt squeek??
any ideas, i am thinking it is the zinc coating o nthe rotors that needs to be worn out then it will stop
Old Apr 17, 2005 | 11:37 AM
2002 Maxima SE's Avatar
Got a little bit of this myself. Just put on new RTP rotors and Axxis/PBR Deluxe pads. I went out to "bed" the brakes. This involves several 60mph to 30mph stops. Afterward, the pads were pretty quiet.
However, the next morning, when slowing to a stop I get some vibration...like when the rotor/pad are wet. 70mph to 30mph or 40mph to 20mph slow down causes no vibration...but when coming to a stop they do. After driving for a while, this goes away.
Do the brakes need some more time to wear in the rotor?
Old Apr 17, 2005 | 01:06 PM
jjj's Avatar
jjj
try metal brakes
Old Apr 17, 2005 | 01:15 PM
Maxima-Ness's Avatar
Originally Posted by jjj
try metal brakes
are these computer generated responses?
Old Apr 17, 2005 | 02:01 PM
resurrectedmax's Avatar
enthuzed.........
i've been having the same issue with my brembo's and pads since new also.
any help would be great. since the hot weather is almost here, it will be more and more annoying with the windows down.
Old Apr 17, 2005 | 02:30 PM
zourtney's Avatar
my breaks squeel all the time under light braking. I just figured the pads needed replaced, but now I'm not sure...
I don't know how long the brakes have been on the car, I've only had it since September.
Old Apr 17, 2005 | 06:51 PM
tisucka's Avatar
im having the same problem and find it to be very annoying.
any help or suggestions would be GREAT.
Old Apr 21, 2005 | 08:21 PM
enthuzed.........
anyone? 12234546
Old Apr 24, 2005 | 10:44 PM
Imwearingpants's Avatar
My pads sounded like crap with 50% wear, I went to lappens and got the semi metallic ones, and they sound awesome, Im gunna have to change the rears soon. All on regular oem rotors, I dunno, Pads confuse me
Old Apr 25, 2005 | 03:02 AM
RAZORFISH228's Avatar
You have to use Nissan OEM pads on new rotors which are softer pads.
Old Apr 25, 2005 | 06:32 AM
NCTRNL's Avatar
I just resurfaced my front rotors on Saturday at O'Reilly's and bought Wagner Thermo-Quiet Ceramic pads. They are quiet and they work great.
Old Apr 25, 2005 | 07:03 AM
dmitry82's Avatar
I had the same problem with my Brembo slotted/drilled rotors and Hawk Plus pads!!! My master told me that the pads are not soft enough! So... I changed them to Akebono pad's!! Now it work's perfectly!!!
Old Apr 25, 2005 | 07:44 AM
screamindman's Avatar
I'm running Hawk pads on Brembo blanks that were cross drilled and slotted (RACECONCEPTS) and I'm not getting any of these noises. Did you remember to put the "gorilla snot" stuff on the side of the pads that don't grip to quiet the pads? Trying to help.
Old Apr 26, 2005 | 11:45 AM
Max_Gator's Avatar
I've got to do brakes on both my 96 and 2000.
One thing I've learned is that few shops seem to be able to do Nissan brakes without them squeaking.
I went through this the last time with my 96 and ultimately had to take it to Nissan to get them to fix it. That was after trying to get the shop that did the original install to fix them 3 times.
I've encountered many Nissan owners - Altima and Maxima - that only get the noise issues solved by Nissan.
Old Apr 26, 2005 | 12:19 PM
spiromax's Avatar
Seoul Man
I just got RTP rotors with Axxis/PBR Ultimate pads, and after the initial break in period most of the noise went away. My brakes feel very good, and they are very quiet now. Occasionally I hear a mild squeak, but only when I'm slowing down from moderate speed (around 40MPH). I've heard people say that it's normal to hear some mild noise from the Axxis/PBR Ultimates, especially when they are cold or not being pushed very hard, since they are more aggressive pads (not as soft) as the OEM pads.
Apr 16, 2020 05:15 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Socalstillen
Sep 26, 2015 12:01 PM
