New rotors also need new pads?
Old Apr 17, 2005 | 11:29 AM
Fiona2k2Max's Avatar
just wondering when you put on new rotors, is it better for you to change the pads also?? and why is that?
because my steering wheel is shaking and my friend is recommanded me to change the rotors and pads...cuz i dont want him to rip off my a$$.....
thank you guys
Old Apr 17, 2005 | 11:32 AM
2002 Maxima SE's Avatar
I'm going to say yes. Not sure if this is exactly right, but the break in part of the new rotor comes from the pads leaving material on the rotor. New pads are more coarse.
Also, if your old pads are in any way uneven, it will affect the rotor's performance.
Old Apr 17, 2005 | 11:40 AM
so will this cause the rotor to be warped?? or it's just gonna affect the stopping power??
because when i put on my new rotors, i didn't replace the pads...so they were warped after about 3k miles....could this be the uneven brake pads?
Old Apr 17, 2005 | 11:41 AM
SR20RACER's Avatar
thank you guys
Unless your pads are new I would replace them when you change the rotors. For the cost ($50) might as well start new and break them in together. I just spent $173 replacing my front rotors and pads. Good Luck.
Old Apr 17, 2005 | 11:48 AM
Not sure if old/uneven pads can cause rotors to warp.
Old Apr 18, 2005 | 03:55 PM
latinojerza's Avatar
warped rotors
traveling back from ny to north carolina my back passenger side wheel started making a while driving and when the brake was applied could this be a warped rotor?have a 2003 maxima with 36000 miles on it brake pads look fine
Old Apr 18, 2005 | 04:04 PM
Lontar1's Avatar
Puerto Rico-Maxima Lover
actually you should unless the pads are new. Why go thru the hassle of doing the job twice. This is the main reason why it is done. But if you still have "good Old Pads" like we said in spanish" Con Carne = With Meat" then you shouldn't.
Old Apr 18, 2005 | 08:55 PM
screamindman's Avatar
Definately change the pads, even if you use New stock pads. It's not worth the headaches if the old pads end up messing up the new rotors. The mechanic has to take apart the calipers to get to the rotors, so it's the perfect time to change the pads. If you want decent pads, grab Hawk pads, they are a little pricey ($110 for front and rear), but they are real nice. Some people would say that they are straight butta.
Apr 16, 2020 05:15 AM
NmexMAX
May 23, 2016 07:38 PM
Derrick2k2SE
Nov 19, 2015 10:14 PM
Socalstillen
Sep 26, 2015 12:01 PM
A32goldylocks
Sep 2, 2015 06:39 AM
