tail light/ brake light question
Old Apr 17, 2005 | 03:05 PM
willkim's Avatar
just swapped out for 2000 SE lights... easy swap.. plug and play
however both my tail lights don't work when i turn on the headlights. however, both brake lights work when i brake. Isn't this the same bulb? what's going on here? do i need new bulbs?
Sorry... i'm a dunce when it comes to electronics.
Old Apr 17, 2005 | 03:12 PM
LA02MAX's Avatar
since the bulb is a dual filament, you may not have it in right...just try flipping the bulb around and it should work...you have the 7443 correct? because if you have the 7440 i think its a single filament and wont work...
Old Apr 17, 2005 | 03:17 PM
willkim's Avatar
is it possible for one of the filaments to burn out? so that my brake lights work but my tail lights don't work (with headlights)
Old Apr 17, 2005 | 03:20 PM
LA02MAX's Avatar
well im not really that electrically inclined, so i have no clue...i have just heard of this same problem on the .org a couple of times, and i know that it either has something to do with having the bulb flipped around the wrong way, or that you have a 7440, which is a single filament bulb....some one more intelligent is bound to give you a better answer some time...sorry i couldnt be of greater help for you....did you check to see if your bulbs are in right though?
Old Apr 17, 2005 | 03:33 PM
Ammi's Avatar
350 Detroit Muscle
Yes. I had low beam burn out but high beam still worked.
Old Apr 17, 2005 | 04:23 PM
MIXXMAX's Avatar
Yes, if you have the 2000 taillights, you have to have the 7443 bulb for the brake/parking lights. Also, for the turn signal, you must have a special bulb, "PY21W". The sockets are different as compared to the 2K2-2K3's taillights. I have a 2000 SE, and I did the opposite...I upgraded to the 2K2-2K3's SE taillights.
tsi6001
Oct 3, 2022 10:23 PM
JMag90
Aug 25, 2015 09:17 AM
Nismo_Guy89
Aug 24, 2015 09:49 PM
Samedi
Aug 13, 2015 04:05 PM
