Front passenger side window
Old Apr 20, 2005 | 02:56 PM
nysemt1's Avatar
anybody having problems with there 2k3 passenger side window not going up.
Old Apr 20, 2005 | 03:33 PM
Lontar1's Avatar
Puerto Rico-Maxima Lover
it could be the regulator .. take it to the dealer, you should have warranty , I think....
Old Apr 20, 2005 | 03:37 PM
skierxx5556's Avatar
i dont have a problem with my passenger but my drivers side when i use the auto button will role up and then role itself back down about a quarter of the way its really strange does anyone else have this problem... my cars also a 2k3
Old Apr 20, 2005 | 03:41 PM
nysemt1's Avatar
i just went over my warranty by 600k, i should've gotton that extended warranyt,
Old Apr 20, 2005 | 04:03 PM
XGaSpAcHo
that's the stupid safety feature that nissan put on our maximas. it prevents kids and pets from getting stuck in any of the windows or sunroof when closing. i had this problem on my passenger side window and nissan fixed it for me under warranty. at first they said it was an adjustment and would charge me $60 but then they said they had to replace something which was covered. now it's happening again.
Old Apr 20, 2005 | 04:07 PM
thats stupid but it only happens once in a while sometimes it closes all the way no problem and sometimes it doesnt it gets kind of anoying having to close the window twice.
Old Apr 20, 2005 | 05:07 PM
XGaSpAcHo
yep i've got the same thing. i'm going to have to go there and b1tch because the retards obviously didn't fix it right the first time around.
Old Apr 20, 2005 | 06:40 PM
Bondy009's Avatar
SEARCH...SEARCH...SEARCH....It's called a "window regulator reset". It takes 5 min to do and nissan tries to **** u in the *** by charging 2 hrs labor for it(Thats what they tried with me). All you have to do is take the interior door cover off and hold a reset button while sliding the window up and down and it resets. For some wierd reason my car's passanger side gets screwed up every 2 monthes but its mad easy to fix.
Old Apr 20, 2005 | 06:43 PM
Bondy009's Avatar
.) Remove 3 screws
- Remove grey button under mirror. Remove Screw.
- Remove casing behind dor handing (becareful). Remove screw.
- In handle in door remove black button. Remove Screw. Remove tray.
2.) Take a wide tool and start at the hinge and pop off door panel. Every 4-5 inches there's a pop-off. Go the whole way to the latch. About 6-7 pop-offs.
3.) Lift up on the panel....any presto.
4.) Remove plastic layer to the left of the speaker (dont worry about the glue) it resticks.
5.) Look for a rubber button outlined in red. (about 3-4 inches left of the speaker).
6.) Roll the window the whole way up (dont use auto-up feature).
7.) Press and hold button.
8.) Roll the window down. (dont use autodown feature).
9.) When the window is down let go of the button.
10.) Roll the window up manually and down manually (no auto feature).
11.) NOW ROLL-UP USING AUTO FEATURE AND PRESTO FIXED!!!!
Gotta help out a fellow MA maxima owner
Old Apr 20, 2005 | 10:25 PM
nysemt1's Avatar
does anybody know if there is a recall or TSB on the window regulators
Old Apr 21, 2005 | 08:10 AM
Bondy009's Avatar
its not the regulator. I had the stupid stealer replace two passanger side regulators. The second time he changed the motor and most of the wiring as well. Same result. Its just a stupid problem maximas have just like people who have BOSE have problems somtimes
Old Apr 22, 2005 | 03:50 PM
nysemt1's Avatar
so i go to my dealership to get my front passenger windows fixed. the service rep said that i need a new "glass run rubber". so i tell him ok to go ahead and fix it. i was wondering to myself, do this part even have anything to do my window rolling back up. I think i might have been jipped. any help would be greatly appreciated!!!
Old Apr 22, 2005 | 08:32 PM
XGaSpAcHo
did it fix the problem?
Old Apr 22, 2005 | 09:21 PM
nysemt1's Avatar
i hope so, cuz it would really suck if i can't get my window up when it starts to rain!!
Old Apr 26, 2005 | 03:41 PM
Bondy009's Avatar
heh, you can alwasy roll the window up and press the child safety button and it will stop it. BTW the window rubber is a joke, and the stealer just stole your money...
Old Apr 26, 2005 | 06:23 PM
nysemt1's Avatar
figures, SMF stealership!!! i hate em i tell ya, hate em!!!
lux97Max
Sep 14, 2015 03:54 PM
shaunkey1
Aug 18, 2015 10:09 PM
KGMtech
Aug 18, 2015 09:21 AM
follyburr
Aug 7, 2015 09:50 PM
BassAddictJ
Aug 4, 2015 11:38 AM
