5 gen alignment specs?
Old Apr 21, 2005 | 11:46 AM
dennisuello's Avatar
anyone have alignment specs laying around?
Old Apr 21, 2005 | 11:58 AM
LA02MAX's Avatar
http://forums.maxima.org/showthread....lignment+specs
there ya go...should have all the info you need
Old Apr 21, 2005 | 12:09 PM
NmexMAX's Avatar
dot dot dot ...
you can also request a printout when you get an alignment, it has the specs/tolerances and your recorded values.
Old Apr 21, 2005 | 12:25 PM
Ammi's Avatar
350 Detroit Muscle
I don't know about where you live but all the alignment shops around here give printouts
Old Apr 21, 2005 | 12:27 PM
NmexMAX's Avatar
dot dot dot ...
that's what I meant ... Trying to be nice ... Because that's the only time you use the specs ... after you get an alignment, and they're on the sheet soo, sort of a useless ? IMO
Old Apr 21, 2005 | 01:13 PM
i had new tires and alignment done in Jan. now, it's April and my front tires are worn half way down. (rears look new still) I took it back to realign, they did so and gave me a print out, but when I got home I noticed that the print-put said "95-99" Maxima on it. I just wanted to check if the specs were the same.
My current specs:
Camber:
Left Front 0.0
Right Front -0.1
Cross Camber 0.1
Caster:
Left Front 2.4
Right Front 2.3
Cross Caster 0.1
Toe:
Left Front 0.05
Right Front 0.10
Total Toe 0.16
The specs for min/max & nominal look the same for 2k as for 95-99 though, except for total toe.
matts95max
Apr 23, 2025 10:44 AM
alahjahwan09
18
Sep 21, 2015 09:12 PM
bbsitum
Sep 11, 2015 04:55 PM
dcam0326
Sep 8, 2015 11:02 PM
