Question about coilovers...
Old Apr 21, 2005 | 07:11 PM
LithiuMax
One of the main reasons I want to get coilovers is to be able to drop my car moreso than I can with my Teins (2.2" in front, 1.6" in rear with my current setup). Is this possible? Would I be able to tuck while still having reasonable ride quality (since coilovers retain full suspension travel)? Or are there restrictions in the wheel wells which would not allow for, say, a 3"+ drop?
Old Apr 21, 2005 | 11:22 PM
LithiuMax
No one has any idea?
Old Apr 22, 2005 | 12:08 AM
A33 VQ30DEK's Avatar
you can tuck it. Not sure how comfortable they're going to be tho.
Old Apr 22, 2005 | 03:39 AM
Bluesbrekr's Avatar
Doctorate in Detailing
Depending on your wheel/tire setup, a 3" drop may cause rubbing. Many times guys with that much of a drop need to roll the fenders.
Old Apr 22, 2005 | 11:41 AM
LithiuMax
Stock 17's with stock rubber. Will that cause rubbing?
Old Apr 22, 2005 | 12:16 PM
Bluesbrekr's Avatar
You might be ok, but it will probably be close especially over bigger bumps. Not sure about the fronts when turning, though....Go 3" and carefully see what happens.
Old Apr 22, 2005 | 01:08 PM
ColdSHO's Avatar
im about 3.5 lower than stock. tight turns while braking slam my wheels into my fenders, so unless u push the fenders out or get a diff offset rim 3.25 is about the lowest ull be able to go without hurting anything.
Old Apr 22, 2005 | 03:25 PM
LithiuMax
Excellent.. thanks. Got pics?
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
