What do you guys think?
Old Apr 22, 2005 | 11:55 AM
skierxx5556's Avatar
so i have been working on a tail light project for my 03 and finally got them open have been thinking of ways to make these different and need your opinion on this...
no im not really sure about whether this will be legal or not but i kinda like the way that it looks. of course i would put red and amber bulbs in the light or maybe some led's i havent decided yet. i was also thinking of painting the housing body color so that the lights would blend with the body of the car a little more... let me know what you guys think about this...
Old Apr 22, 2005 | 12:03 PM
MacAlert's Avatar
I would say keep the top red and the bottom clear. Then get those bulbs that are silver but flash amber to keep it legal.
Old Apr 22, 2005 | 12:10 PM
LithiuMax
Old Apr 22, 2005 | 12:51 PM
whazzzzuup's Avatar
Just make sure that you seal them back up correctly. If not, the water condensation will make the lights look crappy.
Old Apr 22, 2005 | 01:27 PM
yeah i know what would you guys recommend for sealing them back up? i was going to use some aquarium sealant how do you think that would work?
Old Apr 22, 2005 | 01:29 PM
Metal Maxima's Avatar
SHIFT_om nom nom nom
I think it would look really good with the top half red...nice work, man!
Old Apr 22, 2005 | 01:31 PM
Lowkey718's Avatar
hey guys need help cant start a new thread I am a newbie, anyways yesterday I installed the injen intake on my 2k2 max, but this afternoon i am driving home and the CHECK Engine light came on.....NEED HELP...I was looking back at the old thread cannot find anything relating to this topic..????
Old Apr 22, 2005 | 01:44 PM
MacAlert's Avatar
You probably blew your MAF. Does the car rev past 2500 RPM?
Old Apr 22, 2005 | 01:53 PM
nyautostyle's Avatar
did u disconnect the battery for atleast 3 hours? also did u install the MAF backwards? i did this at first but quickly fixed it.
anyway for the lights i would put red on top and leave the bottom clear. make sure you put the lights back together right otherwise its gonna look crappy
Old Apr 22, 2005 | 02:00 PM
Lowkey718's Avatar
thanx for the reply and I didnt disconnet the battery for 3 hrs, after I install the intake, I just reconnected the battery, so since I didnt disconnet the battery how can I fix this problem with the SES??Should I disconnet the battery for 3 hrs an will the SES come back on? and I checked the MAF isnt backwards...sorry to rain on your post, but its my first mods and I am going crazy thinking my engine will seize on me..
Old Apr 22, 2005 | 02:02 PM
Lowkey718's Avatar
and yes it revs after 2500 rpms,I dont any problem with that so far...
Old Apr 22, 2005 | 02:28 PM
LA02MAX's Avatar
yeah it looks good, but i agree with pretty much everyone else...i think you should leave the top red then just get a chromed bulb to throw in the blinker, and you should be set....
Old Apr 22, 2005 | 02:45 PM
vsamoylov
when you opened then, you used a heat gun or what? you didnt crack them right? keep them red/clear.
Old Apr 22, 2005 | 02:57 PM
i ended up using a dremmel on the drivers side it was alot easier than using the heat gun which seemed to make the lens more fragle than it is already and it cracked pretty easily...
Old Apr 22, 2005 | 03:00 PM
i dremmeld up the lense and i really dont know how i feel about the red on the top heres a quick pick it doesnt fit correctly b/c its the lens from passenger side but you can get a general idea...
Old Apr 22, 2005 | 03:04 PM
Maxima-Ness's Avatar
.........this was the freakest thread ive read all week....
Old Apr 22, 2005 | 03:19 PM
Epacy's Avatar
Unsuccesful STL Coordinator
You're right there is no thread in here that even closely relates to your problem. Good looking, you sack.
Old Apr 22, 2005 | 04:57 PM
Lowkey718's Avatar
just came back from auto zone, the computer said its Evap Emission Control, he said their a leak basically from what he was telling me not enough air going out, is it because I have the factory muffler?? he reset it for free, and the SES light went out, so what should I do next?? Thanx for the HELP..
Old Apr 22, 2005 | 05:04 PM
why dont you look around a little bit instead of jacking threads that have nothing to do with your problem... its not like there arnt 1283643276 threads about intakes and problems with the maf because of them...
Old Apr 22, 2005 | 05:16 PM
Lowkey718's Avatar
ouch sensitive j/k but u made ur point and my bad.....
Teufelhunden's Avatar
can you cut the dividing part in the lens? then making the whole thing red, and go with the full circle led? big round one and a small round one. kinda like g35 coupe tail? our tails suck, you cant really do much to it.
Old Apr 22, 2005 | 05:21 PM
i think i understand what you are saying and if you were to remove the divider you would have a pretty good size gap between the top and bottom sections... but i do like you idea i think that would look really good!
Old Apr 22, 2005 | 05:32 PM
i know, our circle is way bigger than g35 cp ones. they would look dope, maybe 3 led rings inside? but bigger leds to fill in the circle?
Old Apr 22, 2005 | 05:37 PM
i dont know if i understand you now theres really no way that you can remove the divider in the center of the light unless you did half circles with the led's thats really the only want that you could make this work... btw i have no experience with electrical and led's so if someone would like to help with this project they are more than welcome...
Old Apr 22, 2005 | 06:25 PM
Dr. Roy's Avatar
clear the top and bottom and replace the clear lense on the reverse light w/ a red reflector, then switch the the revese and signal wires,
it would be like the cleared tails (w/ a red revese) that used to be all over ebay but these would be legal
Old Apr 22, 2005 | 06:32 PM
NismoMaxm's Avatar
I like them all clear. But the top half red does look pretty clean. its up to you man from here on out. good luck.
Old Apr 22, 2005 | 06:41 PM
SCT.MAX's Avatar
I vote for all clear w/red and amber bulbs.
Old Apr 22, 2005 | 06:59 PM
Kevlo911's Avatar
Kevlo for President
I vote someone donate a pair of tails so I can see if I can make some LED tails for 5th gens.
Old Apr 22, 2005 | 07:23 PM
MaximaPolak's Avatar
I am also doing this but I will be painting mine eather black or body color (majestic Blue) Leave the top red and clear bottom since you need a red reflector at the rear of the car.
Old Apr 22, 2005 | 07:35 PM
NismoMaxm's Avatar
Yeah what id really like to see is for some altezza style lighting to come out for the 5th gens. My buddy has the altezza II on his max and he has it so it looks like there are little LEDs lighting up just that large circle. It looks very similar to that of the skyline. Very nice and sharp. Thats what we need for our rides boys!
Old Apr 22, 2005 | 08:02 PM
ChromeSE5's Avatar
if you paint it majestic blue, will you also do your headlights that color or leave them black to match your carbon fiber hood?
Old Apr 22, 2005 | 09:39 PM
hmm... i dont know if i fully understand what you are saying so my reverse light would be my brake light/driving light or would you it be the blinker or am i totally off...
Old Apr 22, 2005 | 09:41 PM
MacAlert's Avatar
Don't do whatever he said. That won't look good at all, almost altezza-ish. The red clear would look the best.
Old Apr 22, 2005 | 09:46 PM
the only problem that i have with the red/clear is that the se and gxe tails already have that and im looking to do something that is totally different with this project...
Old Apr 22, 2005 | 10:04 PM
MacAlert's Avatar
Well, the 5.5 Gens don't have a proper red/clear, unlike the SE (black surround). Hence why I think the red/clear on the clear lense would look nice. But I guess it's your project and you do what's best for you.
Old Apr 22, 2005 | 10:09 PM
no i totally agree that it looks really good the way you have described and i appreciate all of the input and ideas that you guys have given but what im really looking for is something that when someone who has an idea of what a max tail looks like and sees mine to be like wow that is really nice...
Old Apr 22, 2005 | 10:20 PM
Ammi's Avatar
350 Detroit Muscle
Do something w/ them because they are nasty
Old Apr 22, 2005 | 10:39 PM
naughtywon's Avatar
If you've got clear corners, go with the clear lens look. Although if legality is an issue you should make sure your top lights flash amber.
Old Apr 23, 2005 | 09:45 AM
Dr. Roy's Avatar
the top of the large circle, (w/ red bulb) would be your brake light, bottom would be reverse and the the small circle would be blinker.
Old Apr 23, 2005 | 10:12 AM
Dr. Roy's Avatar
on second though....after doing a little MS paint magic on that photo,that does looks kinda cheesy,
