Glass Run Rubber
Originally Posted by reygarcia
the part that makes you window go up is the regulator, not the glass run rubber.
the part number will vary by year. what year is your car.
looks like they did. i believe this is the part number for the regulator 80720-7Y000 (RH)
and 80721-7Y000 (LH).
did you have the regulator replaced, if so what is the part number that you have?
that is probably because it took only 2 mins to replace. looks like you got ripped by the dealer. did it fix your window problem?
Originally Posted by nysemt1
well, the window closes, but if i have the same problem again, i'm going to be pissed!!! Figure it this way, if i have the same problem, i should still be under there warranty, so they have to fix it!!!
so what happens today, when i go out for lunch, my front passenger side window does NOT roll up AGAIN. so here i go, back to the stealership to get it replaced. hopefully they will honor their warranty and they'll replaced the right part this time. now the question that is stumping me is, if they mis-diagnois the problem the first time and then they say there was another problem with the (i.e. motor, or something) does that mean i have to pay twice!
shilov
Feb 19, 2024 09:40 PM
JoshG
51
Sep 21, 2015 10:41 PM
