Need Precision Alignment Settings for Autocrossing
If you can convince the guy to use the play in the bolts, you can get maybe half a degree camber adjustment.
Go for zero toe front and rear. Then get as much camber as you can in the front (but make sure it's equal side to side). Also try to get as much in therear as well, also equal. On a max this should give you about 1 - 1.2 degrees negative camber in the front and maybe .8 in the rear. Not ideal, but the best you can do.
knight_yyz
Nov 1, 2015 01:34 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
