Wire question
What..
are you trying to do? The reason I ask is because the wiring diagrams that come from the dealership on things like the stereo are so complicated that you might get confused. But some of my good friends own a stereo shop and I could call them and ask them any questions that you might have. They are the people that have done my stereo! Let me know if I can help.
Originally posted by Mikesmaxatl
Does anybody know were I can get a wiring diagram or code book for the max? I need something that will tell me what each different color wire is. Particularly the wires that deal with the Bose stereo.
if you look around for a wire harness adapter for an aftermarket stereo (ie from crutchfield), you can figure out the function of each wire if they don't give you a color code scheme already...
when i get some time, I'll try to find one and report my findings.
Re: What..
Re: Re: What..
I want to tap into the wire harness that feeds into the BOSE amp for the sub located under the rear deck. I need to find, low level inputs, power, ground, and remote turn on, in order to hook up a bazooka tube.
The amplified Bazooka tube should accept high level inputs and also has the "auto on" feature (turns on when it detects input signal). Also, you should use seperate power and ground lines, not the ones off the bose amp.
The Frye
Sep 2, 2021 11:03 AM
