Any pics of Tein EDFC?
Old Apr 27, 2005 | 05:44 AM
chris'smax's Avatar
Can someone post some close up pics of the tein EDFC uninstalled. I am thinking of trying them on my tosers if they look like they will work
Old Apr 27, 2005 | 08:35 AM
NiZMo1o1's Avatar
umm I wonder if I could use those for the D2's ?
Also Chris good luck with your car , I hope you worked out your bugs..
I just put on the Z brakes... im loving it ..and im very lucky because the calipers has like maybe 2 mm to spare from the rims spoke.. Im glad it went welll. Thanks again
Old Apr 27, 2005 | 08:40 AM
chris'smax's Avatar
Sweet. I am glad you like them. I really wanted to keep them but i had other plans to take care of first . Please send me some pics when you get a chance so i can drool over them
Old Apr 28, 2005 | 12:13 PM
NiZMo1o1's Avatar
will do..~!
Old Apr 28, 2005 | 12:57 PM
Larrio's Avatar
The Definitive AE Master
check hnda_etr's website, he has them on his 5th gen. Or you can check out www.cardomain.com/id/axa_g35 (used to be irvine78 on this forum)
its just a little black box that sits on top of the strut mount area where the strut portrudes
Old Apr 29, 2005 | 12:23 AM
NiZMo1o1's Avatar
the thing is does the EDFC only works for the Tein(doh) because of the top thread.
Im wondering if I could use it for the D2s.
Old Apr 29, 2005 | 12:55 AM
HNDA ETR's Avatar
Still Here... IM me for more..
I know that they don't work ONLY for Tein's... Rod Millen uses the Tein EDFC on his GTO drift car... I believe he uses custom valved Intrax coilovers.
There are 2 things that you would have to make sure of on the tosers, or any other adjutable coilover:
1.) The threads on top of the strut must match with the thread pattern of the EDFC motors.
and
2.) The coilovers must be adjustable using the same kind/size of hex bolt.
Another thing to keep in mind, is that there are multiple models of the Motors, so the threads may not be the same between all the different models of motors.
You're best bet, is to find a shop that has the EDFC in stock and try to convince them to let you test fit a motor... I have a feeling this ain't gonna be easy to do though...
more info: http://www.tein.com/edfcinstall.html
Old Apr 29, 2005 | 01:09 AM
jdmmax's Avatar
OMG
look at that lip!?!?!??!?!?
Old Apr 29, 2005 | 05:25 AM
chris'smax's Avatar
and
Thanks roy,
BTW what PSI were you running when you dynoed 300whp w/ the headers? Also my coilovers are adjustable using a allen wrench Key.
Old Apr 29, 2005 | 09:19 AM
SixxOne's Avatar
Sorry to ***** your post, but that is a nice G35.
Old Apr 29, 2005 | 10:29 AM
HNDA ETR's Avatar
Originally Posted by chris'smax
Thanks roy,
I was running the 3.125 pulley and I believe I was getting around 10.5 psi...
Apr 16, 2020 05:15 AM
NmexMAX
May 23, 2016 07:38 PM
BobTX10
Oct 7, 2015 08:43 AM
bigfrank
Oct 1, 2015 12:51 PM
