Illumina rear adjustments - Easy method?
Old May 1, 2005 | 11:46 AM
Audtatious's Avatar
Bandwagon Lover
Do I really have to remove all the metal surrounds to adjust the rear Illuminas, or should I bend a small screwdriver?
Just wondering if there are any easy tricks to it.
Old May 1, 2005 | 12:01 PM
MacAlert's Avatar
I just stick a small screwdriver in there. Don't have to remove the metal surrounds.
Old May 1, 2005 | 12:05 PM
Audtatious's Avatar
Bandwagon Lover
Yeah, dammit. I'll have to search around for a micro screwdriver. My small ones don't allow access without removing my sub box. Not something I want to do when simply doing adjustments...
Old May 1, 2005 | 12:51 PM
Epacy's Avatar
Unsuccesful STL Coordinator
Try a flathead drill bit or screwdriver bit.
Old May 1, 2005 | 01:45 PM
Audtatious's Avatar
Bandwagon Lover
Yeah, a regular flathead (long/thin) worked. I finally saw the channel where the screwdriver would fit. Hoping for a softer ride now
Thanks!
Old May 1, 2005 | 04:13 PM
Ammi's Avatar
350 Detroit Muscle
I used tip of a fuse
Old May 1, 2005 | 04:19 PM
irish44j's Avatar
retired moderator
there is an opening at the top of the metal surrounds....get a medium length, fairly thin flathead and you can turn the dial by sticking it down through the top...piece of cake.
Old May 1, 2005 | 08:39 PM
housecor's Avatar
I'd recommend just leaving the plastic tabs that hold the carpet on the metal off while running illuminas. Makes for easy access since you just pull back the carpet.
Old May 2, 2005 | 01:39 PM
Epacy's Avatar
Excellent point. I didn't like dealing with those.
matts95max
Apr 23, 2025 10:44 AM
PH98I30
29
Feb 10, 2025 12:03 PM
AcuraLegend
Oct 17, 2016 08:47 PM
AcuraLegend
Sep 22, 2015 04:22 PM
doctorpullit
Sep 10, 2015 06:33 PM
