Amping front door speakers
Old May 6, 2005 | 10:55 AM
  #41
SupaFly's Avatar
I think I would want to take advantage of their bass so, I would use full. Thanks
Old May 6, 2005 | 03:06 PM
  #42
screamindman's Avatar
A nice place to hide the amps is under one of the front seats. Just make sure that the area that has you adjustments is facing rearward so you can access them. You should wire your new fronts directly to the amp, and either get a cross over (or the amp may have one already) so you are not running the bass through the speakers. If you already have a sub, you don't want to run the speakers full range.
Old May 8, 2005 | 04:26 PM
  #43
SupaFly's Avatar
Just an update..
I installed the amp via the High input connection. I am now getting a high pitch whining noise coming from the front speakers. It gets louder when i rev the engine. I am using the same ground that i had on previously. It's connected to an all metal flat surface (no paint). I even tried moving it to no avail. There is a ground line on the high input connection, but i just taped up the end of it and didn't connect it to anything. I also have the remote line running along the drivers side with the new front door speaker wire. Could this cause a problem?
Old May 8, 2005 | 05:41 PM
  #44
TheBigDu's Avatar
Originally Posted by SupaFly
Just an update..
I don't think the remote thing would be the problem. I actually have a little bit of noise myself, but I'm not sure what it is at this time. It's so quiet that I only hear it when the music is paused and the volume is turned way up.
If you really can't figure it out, you could try running another ground to the battery. Check this thread out: http://forums.maxima.org/showthread.php?t=399367.
-Brian
Old May 8, 2005 | 05:48 PM
  #45
SupaFly's Avatar
-Brian
Thanks for the link. I don't currently have a ground wire running from the negative terminal to the body. How would this work to fix the noise?
Old May 8, 2005 | 05:55 PM
  #46
TheBigDu's Avatar
Yeah you do. If you didn't, you'd have no power in the car. That thread is just about adding another one. I guess it's something along the lines of improving the ground. Not too sure...
MikesChevelle
Audio/Video/Electronics
Sep 11, 2016 06:36 PM
vingodine
45
May 21, 2016 12:46 PM
melteye
May 16, 2016 12:02 AM
delerium75
Aug 19, 2015 11:08 AM
kjm900r
Aug 5, 2015 07:14 AM
