I need help with my engine!
Old May 6, 2005 | 05:03 PM
CTmax02's Avatar
Alrite to make a long story short my tranny is slipping bad and nissan is replacing a new one 4 me so I decided to play around with it and took off the knock sensor and now the check engine light is on. I reset my ecu by disconnect the battery and the light is still on so I went to Autozone and they checked it out and it has no codes what sould I do. Sorry for the long post
Old May 6, 2005 | 06:13 PM
Lontar1's Avatar
Puerto Rico-Maxima Lover
stop playing with the engine....what else.. my .02.... disconnect the battery agai for a few hows... if that doesn't work .. go to the stickies and perform the HOW To on a 2002 ECU
Old May 6, 2005 | 06:25 PM
LA02MAX's Avatar
disconnecting the battery doesnt reset the ECU on the 5.5 gens like it does on the 5th gens....you're going to have to use the 2k2 ECU reset procedure as lontar mentioned above...
Old May 6, 2005 | 06:26 PM
LA02MAX's Avatar
here, merry christmas, i found it for you: http://maxima.theowensfamily.com/ecu.asp ...it's not hard, and it takes no time at all...good luck!
Old May 6, 2005 | 06:59 PM
CTmax02's Avatar
thanks for the feedback
shilov
Feb 19, 2024 09:40 PM
James92SE
142
Jan 2, 2024 09:23 AM
msellas
Sep 23, 2015 09:16 PM
Socalstillen
Sep 20, 2015 11:46 PM
seesole
Sep 14, 2015 12:38 PM
