Weird But True...
Old May 6, 2005 | 07:49 PM
max 01's Avatar
Weird But True...
I've tried to ignore it- nahhh couldn't be...they will think I'm nuts but I am convinced that I have water in...get ready for this...in my frame! When I hit the brakes, I can hear it sloshing around. I thought- hmmm ok it's just the sound traveling from the gas tank or other fluids under the hood but no- when it was cold out, it actually froze and near the lower front door I could hear and feel the vibration of a chunk of ice hitting- like a slap wrench dent puller.
Could this water have gotten in at the factory? I never had the body apart except a rear 1/4 but thats on the opposite side. Do we even have hollow tube frames or is it unibody contruction- either way, it's just WEIRD BUT TRUE.
Old May 6, 2005 | 08:11 PM
NisMoN00B's Avatar
+Cru OG
unibody. check your trunk, might have water in the spare tire well.
Old May 6, 2005 | 08:44 PM
max 01's Avatar
no...
It must be in the door itslef then...definitly not the trunk- its in the door.
Old May 6, 2005 | 08:48 PM
S00NR1's Avatar
OU > *
I was just mentioning to some of the OKC guys the sloshing sound I hear from the rear end of the car. I always assumed it had to be the gas tank but had no real evidence that it was, not to mention I had never heard a tank make this much noise before. I still have no clue.
Old May 6, 2005 | 09:10 PM
lalaMAX's Avatar
if it is in your trunk then u might lost one of the rubber seal under the spear tire... if it's in the door check if the hole is blocked...
Old May 6, 2005 | 10:02 PM
maximized2
If you didnt buy your car new there is a process of drilling a little hole in body parts to remove dents. Dealerships use these guys to do this I worked at a dealership awile back and his name was The Dent Guy, look for little black plugs on each side of that door,
Old May 7, 2005 | 01:31 AM
maxfive-O's Avatar
Did you buy you car new? Could it have been in a flood? Weird...
Old May 7, 2005 | 04:18 AM
mingo's Avatar
there are these lil rubber plugs on the bottom of the rocker panel.. take those out and see if water comes out
Old May 7, 2005 | 06:43 AM
maximized2
I would try it just make sure you replug them with some sort of glue!!
Old May 7, 2005 | 08:24 AM
taekwondodude's Avatar
yeah take on of the plugs out
Old May 7, 2005 | 08:26 AM
S00NR1's Avatar
OU > *
OK, so what about the sloshing sound coming from the trunk area -- like I said, I always had assumed that it was the gas tank but now I may be thinking differently after reading this thread.
Old May 7, 2005 | 08:33 AM
Lontar1's Avatar
Puerto Rico-Maxima Lover
I hear the same sound in my car...always thought it was comming from the gas tank.... Damn.. more things to think about
Old May 7, 2005 | 01:12 PM
maximized2
Not sure about you guys with the trunk but I'd be willing to bet that is what it is with Max01's door, doors are what those guys fix most!!
Old May 7, 2005 | 01:47 PM
super6's Avatar
used to have the same thing im my miata, sure as hell it was water in the body. i drilled a small hole in the car, just under the scuff plates. good luck to u man.
Old May 7, 2005 | 10:00 PM
NisMoN00B's Avatar
+Cru OG
some maximas have some type of sealer problems under the rear window (so the dealer says) and behind the tail lights. water seeps in, collects in the spare tire well. my lug wrench ended in rust because of this problem.
Old May 8, 2005 | 10:38 AM
OhOhMax's Avatar
Bleh I had water in the frame of my 4Runner.... but that was because it was submerged so that I could stick my hand out of the window and touch mud/water if I wanted to a couple of times! haha
Old May 9, 2005 | 06:47 AM
max 01's Avatar
Ouchhhh
You are being a little rough on him don't ya think? He didn't say anything wrong...I appreciate your help, trying to help me solve my problem but it wasn't a really big deal at all. Don't be stressin'.
For the one who "feels"--life is a tragedy...for one who "thinks"...I comedy.
Life is short---run nitrous!
AaronL
Nov 15, 2020 11:52 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
05RLS2
Sep 27, 2015 09:24 PM
yamehoo
Sep 24, 2015 10:21 AM
bennuss
Sep 11, 2015 05:55 AM
