Huge Problem. Car keeps dying.
Old May 6, 2005 | 08:25 PM
MY2000MAX's Avatar
ok,
I am having a hard time getting the car to drive. It keeps stalling. It starts up fine but immediately dies. The RPMs shoot up to 1 and drop instantaneously.
And if it does manage to get going, the RPMs keep getting lower and lower until the dash lights come on and the car dies.
What could it be???
I have an auto (if it matters).
Thanks. Really appreciate it.
Old May 6, 2005 | 08:32 PM
jrod1014's Avatar
Do you have an aftermarket intake or something? Methinks vacuum leak... Check all hoses and whatnot... My intake came apart about 2 weeks ago and I had the exact same symptoms. Car would start up fine then immediately die. I found out that my intake had come loose after the MAF so the MAF was not reading any air and obviously since there was no air, there was no fuel. No fuel = engine cut out... Also try unplugging your MAF to see if the car actually stays on... I did this while I was troubleshooting.
Old May 6, 2005 | 08:50 PM
tedo007's Avatar
faster than you think
did you try to reset your ecu?
Old May 6, 2005 | 08:51 PM
nismo0604's Avatar
maf, check the stickies
Old May 6, 2005 | 09:01 PM
MY2000MAX's Avatar
I have no aftermarket intake (everything is stock). I did reset the ECU and it didnt have an affect. Another thing i did was pull the MAF out and see what would happen. Nothing
changed, car still kept dyin, only difference was that with the maf out i couldnt go past 2500 RPM.
MY2000MAX's Avatar
I was also thinking that maybe my alternator is goin.
Old May 7, 2005 | 05:29 AM
MY2000MAX's Avatar
Bump...
Old May 7, 2005 | 06:54 AM
maximized2
Maf Maf Maf Maf!!!!!!!!!!!!!!!!
Lakersallday24
Jun 16, 2019 01:35 AM
JMag90
Aug 25, 2015 09:17 AM
sc10692
Aug 9, 2015 09:37 AM
kirkhilles
Aug 8, 2015 10:53 AM
MikesChevelle
Aug 7, 2015 05:57 PM
