1 bolt to the FSTB is stipped, Help how do I change it
I noticed today that 1 bolt out of 3 is stripped on the left side of the Strut in the Engine Bay, how do I change them?
IS it safe to dive on only 2?
FIRST: to replace the bolt, you will have to pull out the upper strut mount and get a new one (I actually have an extra one, so if you need it, PM me and you can have it for cheap). It is NOT advisable to drive around with one not bolted down, as these bolts are holding the top of your suspension on...
SECOND: read this thread carefully:
http://forums.maxima.org/showpost.ph...59&postcount=3
(very important considering your other thread on this subject)
How hard is it to take off? is that the plate on the top of the stut? The Nut stay stuck but the bolt just spins, and the bolt doesnt pull off. its just a little loose.
Is that ok? the other 2 are tight.
call a dealer and see how much they cost. I have one here that should work for you, but they might be really cheap at the dealer. The part you need is called the "strut mount bracket" and to install it you will have to take off the strut/spring assembly (using a spring compressor of course) and take off the cap nut.....if you don't know what I'm talking about, just have a shop do it...it's easy if you have the correct tools.
Don't forget to get new nuts for the top at the same time
I went looking for nuts for the top Napa and checkers didn't have the exact ones,
Irish how much you want for the bracket,
Checkers had it for 35, but have to wait 1-2 weeks to order
How much with shipping about to 96744 Hawaii
Shopping Cart
Click here if you are located outside the continental U.S.
Product Qty* Price Total
Nissan Maxima (1999-2003 (04/1999-2003 All))
Tokico RIGHT FRONT Illumina Adjustable Strut (Price/Ea.) - PTBB3188 $161.95 $161.95
Tokico LEFT FRONT Illumina Adjustable Strut (Price/Ea.) - PTBB3189 $161.95 $161.95
Nissan Maxima (2000-2003 All)
Progress Technology Sport Springs (Front -1.7", Rear -1.5") - PT40.1521 $179.95 $179.95
Redeem Coupon
*Update item quantity -- Change Qty amount and click "Recalculate" button.
*Remove item from cart -- Change Qty amount to 0 and click "Recalculate" button.
SubTotal: $503.85
Shipping: $16.95
Total: $520.80
Without Shipping How is this, I might as well get it because I'm gonna have to rip appart the front myself. OR know anywhere Cheaper.
Redeem Coupon
SubTotal: $503.85
Shipping: $16.95
Total: $520.80
Shopping Cart
SubTotal: $503.85
Shipping: $16.95
Total: $520.80
SubTotal: $503.85
Shipping: $16.95
Total: $520.80
2. I hope you're not thinking just dropping the car on Progress springs with only Illuminas in the front... get all 4 struts replaced.
My main thing is to fix the front strut mount, 1 of 3 bolts is stripped it just spings in place and the nut doesnt come off because its locked on there
Any suggestion on how to get the nut off so i can change the mount?
Or any cutting tools that will work
Btw, how did ya strip the bolt up there? Was it because your nuts were overtorqued when ya installed the FSTB?
I'll give it to you for $25 shipped shipping normal. If you want it FAST (i.e. 2nd day air or something) you'll have to pay extra.
condition: the piece came off a junked car so it has some minor corrosion here and there, but nothing a little steel wool won't take off. The bolts are in perfect condition - no strippage AT ALL. I do NOT have the nuts that go on top - at least not all of them. I might be able to find 1 or 2 at most, but don't count on it.
Let me know and I'll send you my paypal address via PM if you want it.
a lil OT, but are the top hats from a 4th gen and 5th gen different? would they use the same bolt size? If so, mayb eyou can get that from a junkyard since it the bolt might be from the nissan parts bin...
edit: or i fyou have the patience, i would just go with irish then since it seems like a pretty decent price.
When I went to get allignment done sears told me that one of the bolts was loose, it wasn't loose when i put the strut bar on there. I guess from cornering...
The strut upper mount nuts should be tightened to 39-54 N-m.
siren... email or PM me your address, and I will burn you a copy of the CDROM for either the 2000/2001 or the 2002/2003 electronic service manual. it has all of the schematics you need and "how to's" for repair.
any links with pictures on how to take off.
http://www.innerbean.com/housecor/strut_install.html
http://forums.maxima.org/showthread....&highlight=FSM
The Wizard
24
Oct 1, 2015 08:47 PM
ag90fox
Sep 9, 2015 12:22 PM
