Outside Temp. Display
Old May 19, 2005 | 08:23 AM
upstatemax's Avatar
I have the auto climate control with the outside temp display and I am having a bit of a problem.
It takes about 45 of driving for it to show the correct temp, if I Know it is 75 outside it will first show up at like 50. Then it will slowly creep up to the correct temp (about 45 min). I dont know where the actual sensor is, so I can see if it is dirty...
Where is it? Does (or did) anyone else have this problem? If you did, how did you fix it?
Thanks.
Old May 19, 2005 | 09:46 AM
jkayca's Avatar
I see something like this on both my Max and my Envoy. I garage both vehicle so consequently it is a different temperature when I start out as to when I finish a trip. In winter my garage is about 10-15 degress C wamer than it is outside. I think it's that the car acts as a giant heat sink and it takes time for it to reach the same temperature as it's surroundings. This in turn effects the thermometer.
Old May 19, 2005 | 10:00 AM
Maxima2000SE's Avatar
the sensor is at the top of the dash...one sensor is for the temperature and one sensor is for the auto headlights and i am not sure which one is which but they are located on the ends of the vents for the defroster.
Old May 19, 2005 | 10:02 AM
Maximax2's Avatar
Uh...think that's the sensor for the INTERNAL temp?
Old May 19, 2005 | 10:06 AM
icewake's Avatar
Yea....i'm not trying to be mean but it doesn't make much sense for the external temperature sensor to be located inside. my guess is that it is located around the windshield wipers somewhere. If i'm not mistaking the manual says where its at but dont' hold me to that.
2k1Maxdrvr's Avatar
I thought it was for the auto headlights also
Old May 19, 2005 | 10:22 AM
upstatemax's Avatar
Yeah, thats the one for the internal temp. I just found it in the manual and on the car. It is in front of the radiator on the bottom left corner (if in front of the car). i will take it out and clean it soon, and if that dont work i will price up how much it is to replace.
Old May 19, 2005 | 10:25 AM
2k1Maxdrvr's Avatar
Good luck I hope it works for u!
Old May 19, 2005 | 10:54 AM
MIXXMAX's Avatar
Yeah, look thru the front bumper opening, and you should see it. It's black in color.
Old May 19, 2005 | 12:28 PM
nicks79's Avatar
PM me, i'll send you a page from FSM.
Old May 19, 2005 | 01:52 PM
sorry my bad
Old May 19, 2005 | 05:17 PM
sascuderi's Avatar
Had the same problem with my outdoor temp unit. I sprayed the sensor with electrical cleaner from Home Depot and it worked like a charm. Sensor was fast and accurate again. Used "CRC 2-26 plastic safe lubricant". Its in a dark blue spray can.
Old May 19, 2005 | 06:05 PM
Metal Maxima's Avatar
SHIFT_om nom nom nom
Uhhhh....what?
Old May 19, 2005 | 10:01 PM
cgrubert's Avatar
Cleaning it should help. Normally mine takes no more than 2-3 minutes to adjust if it was in a cold (or hot) garage or something like that.
Old May 21, 2005 | 02:44 PM
sascuderi's Avatar
Ya, since I spayed it with the stuff from home depot(see post above) one year ago I haven't had a problem since!
wiseguy6199
18
Oct 1, 2015 12:28 AM
Maxima Pride '07
Sep 12, 2015 07:29 AM
nismo_gsus
Aug 27, 2015 04:05 PM
egali045
Aug 5, 2015 09:02 AM
