anyone know how to change pvc valve
Old May 19, 2005 | 08:27 AM
jjj's Avatar
jjj
how and where is the pvc valve changed and is it regular maintainenence. wheres the best place to get one.
Old May 19, 2005 | 09:13 AM
Bobo's Avatar
They cost peanuts so it doesn't really matter where you get one, but a parts store would be cheaper than Nissan OEM. While you're in the parts store, buy a Haynes manual and you won't have to ask where it is.
I have 58K on my car and still have the original PCV valve. The Haynes manual details a procedure to test the PCV valve that is quite simple.
Old May 19, 2005 | 12:15 PM
igzy's Avatar
I Know Kwaliti
This is on 3.0 engine... Looking from the driver's side front wheel, PCV is located on the lower left hand side of the throttle body. You will see a thicker rubber hose leading there. It is between the planum (upper intake cover) and throttle body. I removed the air box and MAF to get to it. It is somewhat PIA but can be done within 15-20 mins. I removed it by first pulling the rubber vacuum hose off and them pulling out the PCV with needle nose pliers (access is quite difficult, tight space there). Put some lube around the new one and it will slide in easier into its place. I think it cost something like $7-8 for an aftermarket one... Good luck :-)
Old May 19, 2005 | 12:30 PM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
i used a purolator with no issues. i believe someone said the fram was a pain.
Old May 19, 2005 | 02:33 PM
SCT.MAX's Avatar
I used some off brand at AutoZone. It was 2.65. Very easy. And though I was just replacing because I had 40K mi., it did make a difference I could notice (better pickup).
Old May 19, 2005 | 03:15 PM
PearlWhtMaX2000's Avatar
what does the valve do exactly? (Newbie question)
Old May 19, 2005 | 03:28 PM
PoLo's Avatar
2-Wheelin it...
i can't give details as i'm not 100%, but it has to do with holding oil in based on pressure. it's a spring loaded valve and when enough pressure builds up, it opens up to let oil flow. over time, the spring loaded valve can rot or seize up, thus not letting the oil to freely flow.
Old May 19, 2005 | 04:16 PM
i see. thanx alot.
BTW your car looks Damn good!!
Old May 20, 2005 | 07:33 AM
jjj's Avatar
jjj
there is no haynes manuel available for 2002 maxima yet!!!
Old May 20, 2005 | 07:42 AM
spirilis's Avatar
Incorrect.
The PCV (Positive Crankcase Ventilation) valve supplies a pathway for crankcase gases (produced by the heated oil, but more than that, combustion gases which have leaked passed the piston rings/valve guides/etc.) to be extracted from the crankcase in an emissions-friendly manner (right into the intake manifold where they can be re-burned).
Without proper PCV operation, the extra gases inside the crankcase cause the oil pressure to rise (since it creates a higher "atmospheric pressure" inside the engine's crankcase/oil chambers/etc), which can cause a bunch of other issues (probably all related to oil leakage of some kind--leaking out the seals, leaking into the combustion chamber and burning, etc.)
It's a good thing to replace every ~50K miles. Which reminds me, mine is due ;-) (along with spark plugs, fuel filter, upstream O2 sensors...)
Old May 20, 2005 | 07:46 AM
ghostrider17's Avatar
POSITIVE CRANK VENTILATION = PCV
Just for those that think PVC is the same thing....
PVC = Polyvinyl Chloride, or that white piping so often used in plumbing or h20 type applications.
Sure, I'm a an a$$hole!!
gr
Old May 20, 2005 | 07:56 AM
Puppetmaster's Avatar
Get a FSM then... there's a thread in the General Discussions forum with a link to a site you can download it for free...
Old May 20, 2005 | 09:59 AM
jjj's Avatar
jjj
haynes better than fsm
i have the service manuel, but haynes is much more detail/step by step
Old May 20, 2005 | 10:17 AM
dgmaxse's Avatar
Thanks, boutht a PCV valve a few months ago and have been meaning to ask the same question. Thanks this helps.
Old May 20, 2005 | 10:34 AM
If people are still wondering where it is... there are pics in this thread for both 5th Gens and 5.5 Gens, which was in the Stickies under the How-Tos:
http://forums.maxima.org/showthread....84#post2821784
Old Jul 10, 2009 | 12:54 PM
kisas's Avatar
very easy, but you do need the needle nose and a flat-head driver
Old Jul 10, 2009 | 02:22 PM
Thorzdad's Avatar
Puppetmaster's link now goes to some thread about filters for Injen CAIs.
JoshG
51
Sep 21, 2015 10:41 PM
bumpypickle
Sep 20, 2015 08:22 AM
DarjeelingRose
Sep 15, 2015 01:20 AM
Steven Orozco
Sep 12, 2015 10:41 PM
tardrex
Sep 11, 2015 07:35 PM
