Help...Please!!!
Old May 20, 2005 | 05:21 PM
Omegasrk's Avatar
Help...Please!!!
My front driver side wheel bearing is shot, so I need to replace it. Right now I am trying to remove the center axle nut. For some darn reason it on there really tight. I've used plenty of penetrating oil and a long breaker bar. I've managed to loosen the nut where the leading edge of it is at the cotter pin hole, but from this point on, it just won't budge. Has anyone had/heard of this problem before. Please give me some suggestions, ASAP because I am trying my best to turn in my hub assembly to my local machine shop to have the new bearing pressed in before they close tonight. Thank you in advance.
steve...
Old May 21, 2005 | 02:20 PM
Menasor's Avatar
steve...
Where you able to get the nut off? Did you try putting a tube over the breaker bar for more leverage? The only other things that I can think of are a dremel with a cutoff wheel to cut the nut or impact wrench.
Old May 21, 2005 | 02:44 PM
seventy5impala's Avatar
when i replaced my axle shafts on my 78 CJ5 and nothing seemed to want too work on that axle nut ...i got a good surdy flat head and a hammer, kinda put a notch in the nut and hammered the nut around...it worked...and that was for a 26 year old rusted 2gether pos.....
Old May 22, 2005 | 12:12 AM
spiromax's Avatar
Seoul Man
I got that nut off by using a six foot pipe for leverage. Even with that pipe, I had to put a lot of weight on it.
Old May 22, 2005 | 06:48 PM
Omegasrk's Avatar
Thank you guys for the help. I eventually had to cut the nut with a hammer and chisel. Apparently, the nut was crossthreaded for some reason. I don't believe I was the one who crossthreaded this nut becauase I don't ever recall taking off this nut ever. Weird. Now I have ordered a remanufactored half shaft along with a new hub since the wheel bearing damaged the original hub. Talk about bad luck. Since I am at it and waiting for my parts, its a good time to install the Cattman's ES Suspension front control arm bushings on both sides. I guess that's a good thing.
steve...
quickspe3dmax
Jun 18, 2012 07:54 AM
vansskaterfreek
19
Dec 6, 2005 08:07 PM
Smaynor2934
Oct 2, 2004 04:02 PM
starbrite996
Nov 6, 2003 11:16 AM
