StreetScenes or GrilleTech Grille????
Any recommendation on which one of these i should cop. The grilletech is about 1/5 of the price of the street scenes equip grille for my 2k1, but is it that much cheaper for a reason? Is the thing gonna fall apart?
Basically i was gonna get the SS grille, and just dremel out the existing grille like somebody just did in their writeup recently, but should i save the money and get the grilletech instead? Let me know your experience with either one.
Haven't checked out grille-tech in a while but the last time I did they were in the development process of the 00-01 grille. I have the SS and I LOVE IT, ppl tell me how it changes the whole look of the car. I know the grille tech is available on the 02-03 but I don't like how it seems pushed back... IMO the Street Scene looks much better!!
Originally Posted by Ryals
How hard is it to install the lower valance grille? I just ordered one. I plan to order the main later depending on how I feel about the lower.
Originally Posted by Metal Maxima
Not hard at all. You have to pry away the air dam cover which is attached to the bumper (6 pop tabs) and simply attach. You will need zip-ties in order to attach them, though. The clips they will give you are teh worthlessness.
Hey Metal, is that the chrome SS grille or the other plain one thats cheaper?
Not the blingy, thugged-out, ghetto-cruiser, pImP-Mah-Maximuh y0, inferior finish one.
I purchased the Grille-Tech black, Race style upper and lower grills for my '03 a month or so ago and I love them. I know that everyone was saying that they would rust, but so far so good. However, I do make sure that that I am constantly giving them attention. I wash my car atleast once a week and when I do, I make sure to completely dry the grills. Also, I make sure to pick off the bugs and whatever else the grill catches. The only thing that makes me a little hot was the fact that I already have a little spot where the black paint is chipped off. I guess a small rock chipped off some of the paint, but it really is unnoticeable. At any rate, since I got all three grills for around $85 shipped off ebay, I thought I would give them a try. Good luck on your decision.
Thanks for the imput. I'm gonna go with the Street Scenes non-chrome, since everybody that has one has had a good experience. Imma try that Metalmax writeup to install it. Taking off the bumper seems a bit much.
Tonight though i'm doing that brighten the gauge cluster mod.Metalmax, whats up with the instructions on changing the shifter light color on your cardomain page?
Originally Posted by JB 20th Ann'y
SS grille works nice for me. Only complaint is the length of the lower grille. doesn't go from end to end like I thought. Unless this is the wrong part they sent me I'd check it out first.
It doesn't? You might want to check your mounting, mine leaves no gaps.
To Cut or Not to Cut, That is the Question?
Is it better to cut out the grille to install the SS Grille? I mean can you really see the grille behind it that well if you don't. Something about cuttin on my car makes feel bad. So I take it the upper SS Grille isn't held in by zip ties? where that write up you did metal so i can save it?
Rather than start a new post I'll continue the subject.
Last year I purchased these Street Scenes Grilles USED. It was all faded, but I had my friend clean it up and had them painted black. I finally decided to get them on the Maxima. The upper grille had to come off because it was scratching the main grille. Details and more pics on my cardomain site.
I used what clips I could on the main grille, then put two screws into the bottom part of the grille. It doesnt budge.
I decided to cut out the original b/c you can see it through the new more then not and I thought it looked pretty bad.
As far as other designs, I couldnt find too many others
ahh... .the good old grille comparison..
grilletechs are CHEAP! but looks nice, probably get them from ebay, but they rust, so you must get is rust proofed. (i did that, and had no problems since)
street scenes and JMS grilles are awesome. I love them, but since i have a grille tech, why spend the extra $$.
I would have gottten a street scene grille if I had the opportunity to chose again.
I guess I'll go ahead and chop away!! I've seen so many SS grilles on here, some with and w/o the OEM grille still in. On the few I have seen still in, I could barely see the Grille behind it, except for that max with the black painted SS grille in the above post. I can see that one real clear. Are there differ types of the SS grille, because I swear sometime that some grilles seem to have bigger opening in them than others?
Maybe its because his SS grill is black,and the original is silver,so it stands out. Ive noticed in the few that just put the SS over the OEM grill, you can see the grill under the
SS one if its a bright color (ie: not painted black) or if its in the sunlight.
Im chopping mine out when i get the new grill,early next week.
Originally Posted by sublimer
What air dam cover are you talking about exactly? Are the 6 pop tabs the vertical notches? I was wondering what to do with those when the grill was attached and I figured the grill went in front of them. Also, where exactly to the zip ties attach to?
The zip ties can be attached wherever...in all honesty, attaching the zipties really depends on how thick a persons forearm is. Skinner, longer foreamrs = way more ability to secure. My forearms are neither, and I still managed! I just attached to the remaining screw mounts for the grille fasica.
with all that being said, that black grill over the factory grill still looks better than my untouched stock front end.
Originally Posted by 808MAX-SPEC
Thanks for the comp! I took the pic just for placement and to see how it would look. At this point I'm going to remove the Nissan emblem before I finally strap it down.
maybe if you dont wanna cut out the oem grill,if you painted it black it wouldnt show through as bad
Originally Posted by Triple8Sol
I'm a little late on this one, but the Street Scenes looks WAAAAY better
Im getting the SS grill this week from a .org member,and im gonna cut out the oem grill also. Anybody whos deciding which one to get,ill let you know how it looks when im done
