o2 simulator question
Ok, i did a google search and only found the 1 topic and i have it bookmarked. But comming from someone who has actually installed them, how hard is it? I am pretty sure I am going to get one but i want to make sure that this is something i can do without screwing up. any info or a write up is awesome!
ok well i'm probobly just going to use a butt connector but determining which wires to connect to which ones...how did u figure it out. also, where does the actual thing connect to? maybe a pic would help.
also, do i get a single or double?
use these instructions posted by blackbirdvq http://forums.maxima.org/showthread....ight=simulator
I soldered the wires. Make sure the white wire, after it is soldered to the harness white wire reads somewhere in the 0.3-0.65V range. And don't forget to unplug battery before doing this procedure. many people get high voltage error code because of this.
just a note, the o2 simulator will not solve a heater issue in the o2 sensor. if you are getting a heater code then you can mock the heater function with a 20-40ohm/20 watt resistor.
Unclejunebug
04-02-2016 05:42 AM
Stagnet04
10-11-2015 08:16 PM
