is it me...........
Old May 16, 2001 | 04:06 PM
MaxSEAE's Avatar
OK, everytime i try to do a peel out, i mean a regular one from fast accel....not torque break, i found out if i floor it(with tsb on), the car will not peel off and takes a while for it to rev up really high, but i step on it really fast, but not flooring it, it'll peel out and rev's the rpm much higher and faster....is that just my car or everyone elses?
Old May 16, 2001 | 05:28 PM
[maxi-overdose]'s Avatar
tsb?
wat's tsb? is it the traction control thing?
Old May 16, 2001 | 05:35 PM
2001SE's Avatar
if tsb is traction control then this is what happening:
When you floor it with the traction control or TC the tire is going to spin and the TC is going to kick in and cut the power to the wheels so the car will accelerate much slower. If you press 75% thortle then the wheels will not spin long enough to let the TC kick in and slow you down. That's why when you are in a race or somthing else its better to drive with the TC off.
P.S somebody correct me if i'm wrong
Old May 16, 2001 | 05:36 PM
AznWontonboy's Avatar
hmm i dunno. i just slam it and it spins the tires.
Old May 16, 2001 | 06:02 PM
MichaelAE's Avatar
Hmmm
What's with the Bimmer shot on your sig? I've been trying to figure it out and I figured it was just temporary, but...huh?
Old May 16, 2001 | 06:03 PM
Re: Hmmm
my dream car.. does it offend u?
Old May 16, 2001 | 07:09 PM
MichaelAE's Avatar
Re: Re: Hmmm
Yeah, I'm completely offended by that. I insist that you take it off immediately.
No...it doesn't offend me...just askin'.
MaxSEAE's Avatar
Re: tsb?
YEA, tsb is the traction control.......that's the switch on the right side of the steering wheel of the dash board.....i think that's wat it said on it....TSB....but i'll double check, not sure. i don't know y it's tsb but it is
Old May 16, 2001 | 07:11 PM
Greek to the Max's Avatar
1st or 2nd.
No matter what I do, the car just shifts to the side, 1st and 2nd gear. these tires are perfect for the garbage.
Old May 16, 2001 | 08:27 PM
MaxSEAE's Avatar
Re: 1st or 2nd.
i dont' think there that bad....just wear out a lil fast....i havn't dont' that much peel outs yet but my wheels are a lot rounder and smoother then wat they should be.
Old May 16, 2001 | 08:31 PM
punkdork's Avatar
Re: 1st or 2nd.
Torque steer.. not much you can do about it since we're FWD.
Old May 16, 2001 | 09:18 PM
RcticMax's Avatar
Re: Re: Hmmm
Dude... my dream car too... or was. The only thing that would make it worse is if it was in BRIGHT YELLOW! Any chance you can downsize that thing to something more reasonable. I'm not against the content of the pic, just the size gets to be a bit much. No flame intended. Only luv.
Old May 16, 2001 | 09:19 PM
Re: Re: Re: Hmmm
its off..
Old May 16, 2001 | 09:21 PM
RcticMax's Avatar
Re: Re: Re: Re: Hmmm
its off..
Dude, don't take it off completely. Just make it smaller. It's a cool pic, just not at that size.
Old May 16, 2001 | 10:16 PM
bry2kse's Avatar
I have a 5 speed.. whenever I try to burn the tires a bit.. I get some crazy nasty wheel hop..
Old May 16, 2001 | 11:29 PM
KaxMaxSEAE's Avatar
I haven't actually seen what sort of TCS (tsb=technical service bulletin, tcs=traction control system) the max's have, but generally, a low speed tration control will
a) apply the brakes to the slipping wheel, and
b) cut fuel to the engine to stop wheel slippage.
Either one will slow you down.
If you floor it, do you see the SLIP light on your dash come on? (You should. I do. )
Turn TCS off, then floor it. Better? If yes, then it was your traction control.
Old May 17, 2001 | 12:46 AM
littledog's Avatar
Actually the traction control system doesn't apply brakes. It just cuts fuel and/or shift to a higher gear to reduce power output to the wheels.
Old May 17, 2001 | 09:22 AM
MichaelAE's Avatar
its off..
Rock on...I like the side spoiler graphic you got going there.
Old May 17, 2001 | 11:03 PM
KaxMaxSEAE's Avatar
That's interesting. (I just located that section in the owner's manual.) Usually that's how a high-speed traction control works. Sucks for a low-speed TCS though.
I guess that's why the max's bog down when TCS is activated from launch. They should have just slowed the slipping wheel, rather than cut fuel.
Old May 17, 2001 | 11:34 PM
MaxSEAE's Avatar
AGREED!!!!!!!
Old May 18, 2001 | 01:33 AM
Stardust's Avatar
F---ing Kangaroos
The TCS on the Max is an all-speed system, at least it was on the 99 Max. I have never driven a 5th gen auto with or without TCS so I dont know about the new ones.
Old May 18, 2001 | 05:30 AM
RACEFACE's Avatar
Re: Re: tsb?
Not TSB! TCS. Traction Control System.
TSB= Technical Service Bulletin.
BRIGBOY
Nov 14, 2002 08:30 AM
