Trans shifts hard dealer says Valve Body
Old Jun 2, 2005 | 11:44 PM
xtantmaxima's Avatar
As the title says, my transmission was shifting very hard out of first gear. The car has just over 50,300 miles and the dealer is saying it is the valve body. He is ordering parts and is doing it under the 5yr/60K warranty. I guess my question is...what part is the valve body and how does this fix the problem. By replacing it and having the problem previously is their harm done to the transmission. My 5 year is up the beginning of next month. Thanks.
Old Jun 2, 2005 | 11:48 PM
NmexMAX's Avatar
dot dot dot ...
Mine was opposite, it shifted sluggish real bad, got a Maximum tuning valve body, and now it shifts REAL crisp/hard. .
Old Jun 3, 2005 | 04:58 AM
juniper9803's Avatar
The First Thing You See When You Drop Oil Pan Is The Valve Body.it Looks Like A Maze With Valves And Solonoids To Control Pressure If Any Part Goes Bad It Affects The Way Your Car Shifts
Old Jun 4, 2005 | 11:07 AM
importuner
If the valve body (solenoid pack) is not replaced soon when bad it "does" create damage to the transmission. Nissan has a TSB that says if the valve body is the issue you must first check the transmission fluid condition. If it smells burned and looks black than you must replace the transmission assembly. If it is normal and does not smell burned than all that is needed is the valve body.
Old Jun 4, 2005 | 05:15 PM
zaku178's Avatar
Say what does the Valve body do specifically and how much does it cost? Because I dunno if this is the same.. When I shift Park to Drive or Reverse, I hear a squeek noise. and then goes away, and it always happens. I dunno why.
Old Jun 4, 2005 | 09:11 PM
vsamoylov
i have a spare oem valve body if anybody wants to but it fro mme.
Old Jun 4, 2005 | 09:28 PM
importuner
you wouldn't get a squeak noise from the valve body. the transmission valve body (solenoid pack) controls fluid pressure when shifting. Once the solenoids go back the pressure changing, hence why you get shift flaring and transmission hesitation. i forgot the exact cost of the valve body, but parts and labor should be up there. have a tech hear this squeak noise your talking about. it could be something very simple. good luck
matts95max
Apr 23, 2025 10:44 AM
mvm062
Nov 30, 2020 09:00 AM
BkGreen97
Apr 2, 2016 05:47 AM
Maxboy23
Sep 4, 2015 06:04 PM
jfl330
Sep 4, 2015 01:44 PM
