stillen vs cattman
Old May 16, 2001 | 10:05 PM
crzyballa33's Avatar
who has the better y-pipe?
i hear cattman's is stainless
but ive heard stillen is AND is NOT
stillen claims it is, yet some people say it isnt
wuts goin on??
Old May 16, 2001 | 10:06 PM
Max_Vader_2K's Avatar
Stillen uses......
wuts goin on??
a Ceramic Coat on their Y-pipe.
Old May 16, 2001 | 10:11 PM
bry2kse's Avatar
I also hear that the Stillen piece has a "bees in a can" sound due to its flex joint design. I'm going to be going w/ the Cattman piece.
Old May 16, 2001 | 10:12 PM
Re: Stillen uses......
so....cattman is better
Old May 17, 2001 | 07:12 AM
Y2KevSE's Avatar
Rice Boy in Denial =)
Depends on what your needs might be. If drive around in a harsh environment (road salt, snow, etc.), then definitely go with the Cattman pipe, else the Stillen pipe is good enough.
I don't have bees in a can with my Stillen y pipe...
Old May 17, 2001 | 07:25 AM
punkdork's Avatar
One other thing Stillen is the anti-christ so I recommend purchasing from Cattman... just get in a group buy and the price should be decent.
Old May 18, 2001 | 07:07 AM
Fast Walker's Avatar
[QUOTE]Originally posted by crzyballa33
wuts goin on??
[/QUOTE
I just installed the cattman pipe yesterday.
It is way lighter than stock unit went on easy.
muffler shop refused to install it something about feds?
only complaint is you need to remove 2 hanging brackets and no new ones are provided so you need to customize one.
wow what a difference. It will pin you back under heavey pedaling.
Old May 18, 2001 | 09:20 AM
Desert Pearl's Avatar
I chose to go with the Stillen y-pipe because of it's two piece design. I was doing something a little different by also replacing my front exhaust manifold to hopefully gain some lost HP by having a CA/NLEV emissions setup on my Max. If this experiment didn't work, I could have used one piece of the Stillen pipe like everyone else with a 2001 or CA/NLEV Max. Luckily this was not necessary since my experiment went okay. If you want more info, you can check out my site (http://<b>http://www.desertpearlmax....YPipe.html</b>
Performance-wise, I think they are about the same. I got 15hp with my Stillen and I don't recall anyone getting too much more or less with the Cattman pipe. As it was mentioned earlier, if you do live in a harsh environment, you may want to get the Cattman because it is stainless instead of "Jet Hot" coated. If price is a bigger concern, then go with the Stillen and save the extra $100.
Old Jun 2, 2001 | 11:15 AM
y2kse's Avatar
Bzzzzzzzzzz . . .
Have you voted yet?
http://forums.maxima.org/showthread...?threadid=43035
and
http://forums.maxima.org/showthread...?threadid=43284
Fbana41
Aug 29, 2016 12:18 PM
05RLS2
Apr 14, 2016 11:49 AM
Nv2dmaxmd
Oct 19, 2015 05:37 PM
Stagnet04
Sep 14, 2015 11:28 PM
