Weird water in trunk problem!!
Old Jun 9, 2005 | 08:06 PM
leungjc78's Avatar
Today I opened my trunk and noticed that the cover is wet.....so I remove it as water dripped out and found out the 'wood' cover is soaked and bent. I lift that up and viola, the spare tire is IN water....the whole spare tire compartment is fill with water and signs of rust all around.
My only guess is that it's rain water as it rain for a week straight, but the question is, HOW it got inside....
Gonna make an appointment with the dealer, but I like to ask if anyone have a similar problem....or knows what's going on.
Thanks!
Old Jun 9, 2005 | 08:24 PM
Klutch's Avatar
Sounds like one of the rain channels is leaking. Put a garden hose to work and you'll find the leak.
Old Jun 9, 2005 | 08:48 PM
traderfjp's Avatar
It might be time to change the rubber seal around the trunk. Did you check to see if it's sitting properly?
Old Jun 9, 2005 | 09:04 PM
upstatemax's Avatar
check to see if one of the water drains is plugged, it will back fill and drain into your trunk...
Old Jun 9, 2005 | 09:05 PM
Nomad's Avatar
Get in the trunk and ask someone to water your trunk area take out floor mat donut and stuff. also don't forget to remove all the inside panels arround trunk lock. I had the same problem was pissed off of drying the trunk after every rain. But problem was easely fixible (in my case). Ayte after u found out which side was leaking just use some jbkwik or silicone. This kind of leaks are caused by small almost invisible cracks beetween metal panels. Especcialy if your car had rear damage. Good luck.
P.S. had the same problem on my 4th gen, fixed it the same way.
PM me for any Q.
Old Jun 10, 2005 | 05:30 AM
RF951's Avatar
Did you change your tail lights? WHen I changed mine I missed a spot with the sealant and had the same problem.
Old Jun 10, 2005 | 07:12 AM
Bondy009's Avatar
I had the same problem....No clue what happened. After winter, I was washing my car about mid-april, take out spear and see that its swimming. I have graden hosed and no clue, doesnt look like any leaks. Might be the plug on bottom that was loose.
Old Jun 10, 2005 | 06:41 PM
leungjc78's Avatar
I did change the taillight, but that was 2 years ago........but it's could be the source of the problem. I'll check the sealants as well..
Thanks.
Old Jun 10, 2005 | 07:13 PM
LA02MAX's Avatar
here, this may help: http://forums.maxima.org/showthread....ht=water+trunk
i remember reading that thread a while ago, and there were a few helpful hints...
Old Jun 10, 2005 | 07:26 PM
soundmike's Avatar
Very sound, Mike
There are several gaskets (best way to describe them) along the floor of the trunk. Check to see that they're all there and not loose.
Mar 12, 2020 12:06 AM
t6378tp
Sep 29, 2018 04:27 PM
bennuss
Sep 11, 2015 05:55 AM
rbaker100
Sep 6, 2015 02:46 PM
Hailstatejig
Sep 2, 2015 06:52 AM
