Stillen Fstb Installation
Finally received the Stillen FSTB! According to the installation sheet, Install strut tower rings onto strut tower. Torque nuts to 43-58 ft-lbs.
Which torque is correct anyways? 43? 44? 45? etc.. You get my drift. Because the torque on the nuts for the bar is stated to be 20ft-lbs.
I have a courtesy FSTB and the specs on that said the bolts should be torqued to 35 ft-lbs......58 seems kind of high, but the important thing is that the bolts on there are tight enough. I say just torque it to around 45 or so.
Originally posted by virginia2001
the three bolts at the top of each brace should be torqued to 32-38 ft-lbs (according to the shop manual). the bolt connecting the rod to the brace should be torqued to 20.
have fun.. hope you bought the RSB as well.
how to...?
Re: how to...?
Originally posted by MaxedOut2g
...i was wondering exactly how do you measure for FT-LBS?
You have to have a torque wrench to do this. it is a special (rachet {sp} style) wrench that disengages when a certain amount of force is applied to it ... i.e. when you have a nut on a bolt and it reaches the end to more you turn the nut the more ft/lbs of torque you are adding.
Re: Re: how to...?
Re: Re: Re: how to...?
Originally posted by jashick
You can pick up a cheap one from Pep Boys for about $20
Cheers!
Originally posted by mdeal
I would recommend a Craftsman torque wrench: good quality plus can be returned if faulty. You might pay a little more, but you get what you pay for.
I agree.....I have a craftsman torque wrench....cost me $70, but is really nice
Re: how to...?
i should be receiving my Courtesy FSTB 2morrow cuz its the 5th day, and this being my first REAL mod, i was wondering exactly how do you measure for FT-LBS?
Re: Re: how to...?
Originally posted by RACEFACE
I love my Stillen FSTB. This thing is a work of art. I don't know if I should install it. :-) Way better than FAST bars that are on Civics.. ewww.
It's easy... took me about 10 mins.
Re: Re: how to...?
Go on and install the sucker. Have a blast!
MaxLife17
Jun 27, 2019 01:37 PM
