How to open up the valve in the heater core to do a coolant flush
Old Jun 15, 2005 | 10:45 PM
cobalt416's Avatar
Hi Guys:
Am planning to do a coolant drain/flush according to directions from the motorvate guy's link. Does anyone know hot to open the valve in the heater core in a 2001 max ? The directions he gave on his link was for a 4th gen.
Thanks. Cheers.
Old Jun 16, 2005 | 06:04 AM
igzy's Avatar
I Know Kwaliti
I think the simplest way would be to turn up the heat to max while you are doing it and that would open the heating system. You can run it for a minute or two with no danger of overheating providing that the car is cold...
Old Jun 16, 2005 | 09:00 PM
cobalt416's Avatar
i have automatic climate control thou...
Old Jun 16, 2005 | 09:22 PM
foodmanry's Avatar
Da Roller Coaster!
Turn the auto climate to the max with only the vent (no A/C). That is the same thing.
Old Jun 17, 2005 | 07:13 AM
woosh's Avatar
skip that section, not worth the hassle, just run the heater for 10 min, it should be circulated out.
You can fill and redrain with water 2 times if you really want to go after the amount in the core.
Old Jun 17, 2005 | 10:01 AM
cobalt416's Avatar
so just turn the auto climate to max, and run the heater for 10 mins ? without the engine on, i assume, just the fan, rite ?
Old Jun 17, 2005 | 10:16 AM
kcowden's Avatar
The engine needs to be running to flush the coolant and the fan doesn't need to be on for the coolant to flow through the heater core. It just helps circulate the hot air.
Old Jun 17, 2005 | 10:33 AM
Digger01's Avatar
coolant change
a while back i used this procedure to change my coolant. Its a write up on the Motorvate.com site.
Partiall copy of write up;
Automatic Climate Control
If you have the Automatic Climate option (as shown below) you need to do the following to open the valve in heater core:
Turn the ignition switch from the "OFF" to the "ON" position
With in 5 seconds of being switched "ON" push the "OFF" button on the
climate control for at least 5 seconds.
Press the "HOT" button 3 times
Press the "DEFROST" button 2 times. Code 43 will be displayed.
Wait 10 seconds before switching the ignition to "OFF"
I located it on this site:
motorvate.ca v2.0 - *THE* DIY Maxima Website Please Support motorvate.ca
Good luck!
Old Jun 17, 2005 | 04:20 PM
cobalt416's Avatar
thx for the info digger01, i saw that on motorvate site as well. i don't have a 'HOT' button on my 2001, would that be the same as pressing the 'ECON' button ? U have a 'HOT' button your 2000 ?
Old Jun 17, 2005 | 05:26 PM
reMaxxxK's Avatar
years ago I flush my old civic with put the running water hose in the radiator (top in bottom out) and keep the engine run about ten minutes, no sign of temparature rising, maybe I am lucky not mess up the engine, what do u guys think? I might want to try it again on my max
Old Jun 17, 2005 | 07:02 PM
Maxima-Ness's Avatar
Anyone know a linky to a write up on this for a 5.5 gen? Id seriously hate to mess this up...
Old Jun 20, 2005 | 06:02 AM
Digger01's Avatar
Cobalt,
No i dont have a 'HOT' button - its a dial... I cant recall? but i think your right, after fooling w/some buttons the code appeared in the radio and you could here the remainder liquid trickle out into the draining pan- not much.
didnt have the guts to go after the drain plugs on the engine-figured i got enough
and didnt want to screw anything up!
Old Jun 20, 2005 | 09:12 AM
cobalt416's Avatar
i hear you, i don't plan to go after the drain plugs on the enginer either. i will just do the drain/flush/refill, easier. am plannining to use toyota red coolant.
Old Jun 20, 2005 | 09:51 AM
Digger01's Avatar
let us know how it turns out-
I wanted to replace the hoses maybe even with colored silicone one's that would be on the next flush, I have 87k miles on this car
Old Jun 20, 2005 | 10:16 AM
P. Samson's Avatar
There is no coolant control valve for the heater core. Coolant is free to flow through the heater core anytime the engine is running. Temperature control of the air is accomplished using AIR control doors/flappers and the mixing of cold air from the evaporator and hot air from the heater core depending on the Mode and temp selected.
Old Jun 20, 2005 | 06:40 PM
Larrio's Avatar
The Definitive AE Master
IIRC, when I was flushing my coolant out last month if you do the first two steps on the motorvate site a code will appear and then you can adjust three settings by turning the temp **** on the auto climate
Except I didn't know what code meant what for the 5th gen, but i could here something opening and closing
Old Jun 20, 2005 | 07:36 PM
P. Samson's Avatar
You are not hearing this chaps. You are trying to open a non-existant coolant valve. The heater core coolant control valve was engineered out on the Gen. 4 and subsequent cars.
user 11122324
42
Jul 18, 2022 03:35 PM
Miket2006
Mar 1, 2021 03:55 AM
howardis
Dec 11, 2019 06:10 PM
TKHanson
Nov 24, 2018 01:39 AM
tseng1023
Oct 15, 2015 08:30 AM
