LED Window/Lock Switches Help?
Old Jun 16, 2005 | 04:56 PM
philzaga's Avatar
I just got finished swapping LEDs into my switches, and the LEDs work fine. My problem is that my driver's side rear window switch does not work. I swapped the switch over to the passenger side rear and the window rolls down fine. Also, the switch for that window on the driver's control does not roll it down either. So I know that it's not the switch itself because it works on the other side and it shouldn't be a fuse either because it only doesn't work on one window. Does anyone have any ideas on what the problem could be? Thanks.
Old Jun 16, 2005 | 06:27 PM
merovi's Avatar
u prolly F'd up the circuit board like i did. I can't roll down my passenger window. I have no control of that window from the master switch and can only put it up from the door switch to that window. it sucks but metal maxima may be finding a cure soon so we will not have to buy a new control switch.
Old Jun 16, 2005 | 06:31 PM
Metal Maxima's Avatar
SHIFT_om nom nom nom
Switch is indeed shot.
Give me a few days, I should have a way around this.
Old Jun 16, 2005 | 06:35 PM
philzaga's Avatar
my master control is fine, it can control all the windows except for the one behind the drivers seat. the switch for that particular window does not move the window either. but the SWITCH itself works on the other window, the one behind the passenger seat. so its not the switch. im beginning to think that either the wires somehow got messed up or the motor is dead. what you guys think?
Old Jun 16, 2005 | 06:41 PM
I THINK...you have one VERY sexy Max, welcome to the .org.
I think the motor might indeed be shot, your next best bet is to take the door panels off of the rears and swap motors.
The link to the thread in which I will be bypassing the OEM switch can be found here: Aimable master switch
Old Jun 16, 2005 | 06:45 PM
philzaga's Avatar
yeah i put the switch that does not work on another window and it worked. thanks for the compliment and the response.
edit: i saw your cardomain site and was wondering if u got a how-to for the climate-control led mod. thanks.
AaronL
Aug 8, 2020 10:31 AM
mpbclutch33
Dec 26, 2015 11:11 AM
trsandrew
Oct 25, 2015 02:47 PM
leatherneck
Sep 30, 2015 09:16 PM
