2 quick questions
Old Jun 17, 2005 | 01:57 PM
amomaxima's Avatar
2 quick questions
1) I did the anniversary edition painting for my stock chrome lights and i have water appearing in the passenger headlight. Does any one have a remedy for the probelm? I never added more silcone to the headlight beyond what was left after doing the mod. So i am asking what should i do, add silcone or something else.
2) Also has anyone done any modification to the stock automatic shifter. I once saw a setup that made the stock shifter look like a manual with a boot and a manual shift ****. The guy also moved the overdrive to the center console. Has anyone ever seen anything like that? Does anyone know where to get the anniversary shifter for the auto, cause i cant find it.
Appreciate the help
Old Jun 17, 2005 | 02:02 PM
zax 20th ae's Avatar
You should of put a small bead of silicone sealent around the whole light when you put it back together.
Old Jun 17, 2005 | 02:06 PM
Or if you don't feel like taking them apart again,
remove your headlamp, take your bulbs out,get a blowdryer, and use the blowdryer to blow air into the lamp where the light bulb hole is i know it takes a while but it will all dry up...............The water will come back unless you do the cilicone/silicone bead around the lamp.....Good luck
Mar 12, 2020 12:06 AM
pears
Sep 18, 2015 05:25 AM
ef9
Buyer/Seller Feedback
Sep 10, 2015 10:13 PM
Johnny9595
Sep 3, 2015 05:18 AM
