Check engine light question......
Old Jun 21, 2005 | 06:17 PM
BeSeenWithGreen's Avatar
My body was trying to be funny and unplugged the TPS plug. So I got the SES light on. Will it turn off by itself or do I need to reset the ECU? Thanks Greg.
Old Jun 21, 2005 | 07:32 PM
Stardust's Avatar
F---ing Kangaroos
Disconnect the battery and call it a day
Old Jun 21, 2005 | 07:39 PM
I thought that does not work on02-03 but I'll give it a shot
Old Jun 21, 2005 | 07:47 PM
Stardust's Avatar
F---ing Kangaroos
it should work on all 5th gens
Old Jun 21, 2005 | 09:20 PM
LA02MAX's Avatar
nope, this is how to do it: http://maxima.theowensfamily.com/ecu.asp
the 5.5 gens are totally different than the 5th gens...that's a very common misconception...
Old Jun 22, 2005 | 12:33 AM
Thanks I try it tomorrow
Old Jun 22, 2005 | 03:48 AM
jasba's Avatar
In another thread someone mentioned that timing is critical in the process to reset your ECU, I agree. I tried it about 15 times before I got it right, but the light has not come back on so far....[fingers crossed]....
Old Nov 2, 2007 | 06:50 PM
02SE6MT's Avatar
i just tried exactly what theowensfamily.com said to do, many times i tried, still i cannot get the engine light to light after waiting the 7 seconds and pressing gas for 10. any reccomendations? thanks in advance
Old Nov 3, 2007 | 01:32 AM
boris's Avatar
[/QUOTE]many times i tried, still i cannot get the engine light to light after waiting the 7 seconds and pressing gas for 10. any reccomendations? thanks in advance[/QUOTE]
I'm a musician and i use my metronome for timing (beep-beep-beep once a second..) Never got wrong. 1st beep - turn the key; 4th - floor the pedal 5 times, once on each beep; wait 7 beeps, on 8th floor again and wait at least 11 beeps (actually a little more till the light starts blinking). Release the pedal. Read the codes if needed. Floor it again for 11 or more beeps (the longer the better to be sure). Return the key to off position and you are done. Good luck.
CorollaULEV
30
Aug 9, 2021 08:11 PM
Justinmc760
Aug 23, 2015 03:10 AM
maxinout93
Aug 20, 2015 02:17 AM
beboski
Aug 16, 2015 05:23 PM
Flores94
Aug 11, 2015 12:53 PM
