Courtesy FSTB question
Old May 19, 2001 | 10:46 AM
Greg's2kGLE's Avatar
I got a Courtesy FSTB used for a good price. When I tired to line it up with the bolts on the strut tower, the driver's side wouldn't line up because there is some metal piece that is holding the intake that gets in the way. How much of this do I have to saw off? The guy I got it from said about 1/4". Is that alright? Thanks!
Old May 19, 2001 | 11:32 AM
UMD_MaxSE's Avatar
Got Bent?
Yeah. If you have the older version of the courtesy FTSB, you will need to saw off a bit of that metal clip. Just take a hack-saw to it and it should fit just fine.
Old May 19, 2001 | 01:27 PM
UMD_MaxSE, thanks!
Old May 19, 2001 | 02:39 PM
punkdork's Avatar
If you saw into the bolt hole at all you've gone too far.. start conservatively... doesn't take much at all.
Old May 19, 2001 | 05:50 PM
MaxedOut2g's Avatar
torque wrench
what type of torque wrench am i going to need to put it in?
there were like 3 sizes, 1/2", 3/8" and another one...which one?
Old May 19, 2001 | 07:08 PM
killrwheels's Avatar
Courtesy
You have the older 4th Gen bar as the new one needs no cutting. I believe that Courtesy Nissan still has thread to show how far to saw piece. Also use search feature becuz' someone had pictures recently.
Old May 20, 2001 | 01:32 AM
punkdork's Avatar
Re: torque wrench
Get a torque wrench that can handle at least 50 ftlbs and fits your existing socket set (assuming you have one).
Old May 20, 2001 | 09:44 AM
UMD_MaxSE's Avatar
Got Bent?
you can get a 3/8" wrench and then get adapter sockets that let you use 1/2" sockets also (and vice versa) .....so go with the size that you have the most sockets for.
Old May 20, 2001 | 10:02 AM
Re: Courtesy
Does anyone have these pictures? I tried searching but couldn't find anything.
Old May 20, 2001 | 10:09 AM
punkdork's Avatar
Re: Re: Courtesy
I don't have pics but I can take some later. Just grab a hacksaw and go for it. The metal cuts easily. Trim a little and check the fit. Trim a little more and check again. Remember, the bolt hole should be intact, if you cut through it you've gone too far.
Old May 20, 2001 | 10:10 AM
Thanks for all of your help guys!
Old May 20, 2001 | 10:11 AM
punkdork's Avatar
Re: Re: Re: Courtesy
Okay so I just searched www.google.com and found the following link by looking for "courtesy" and "fstb"
http://www.chrislehr.com/maxima/fstb.html
Old May 20, 2001 | 10:15 AM
Re: Re: Re: Re: Courtesy
Thanks for that link, that is exactly what I needed
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
