newbee need help install rear spoiler
Old Jun 25, 2005 | 11:25 PM
reMaxxxK's Avatar
Hi guys, got a oem spoler from friend and want to put it on my car, running to home depot get all the washer and hardware, now how could I center it before drilling hole? is that a template that I can get somewhere? also I need the gasket which I believe was large piece of double side tape, anywhere have this parts for sale or custome/home made?
appreciate all the help.
Old Jun 26, 2005 | 02:53 AM
MIXXMAX's Avatar
What I did when I installed a spoiler on my '95 was that I measured the centers on each mounting bolt so that when you drill thru the trunk the holes line up perfectly. Line up the spoiler on the trunk centering to the fact where you are going to mount it. Pick a reference point on each side of the trunk (left side and right side). Measure it to the center of the pedastal mounting bolt. This is your centerpoint. Also, double check the outer ends of the spoiler of each mounting bolt to see if they line up perfectly from each side of the trunk. Lightly mark placements on trunk. Place masking tape on the trunk where you're going to drill. Double check again to see if the spoiler mounting bolts line up. Now drill holes about 1/8" biggger than the bolt thickness so that the mounting bolts fall straight thru. This will give you some slight play, if your centering is off. Before mounting final assembly, apply strong 3M double sided tape on outer pedestals of spoiler so that it mounts properly. You're done.
Old Jun 26, 2005 | 04:21 AM
specsgirl's Avatar
Mixx has some good advice for you...follow it and you'll do just fine.
Old Jun 26, 2005 | 08:58 AM
reMaxxxK's Avatar
thanks mixmax
Wolvee
Apr 20, 2018 05:34 PM
Huttig2009
Sep 25, 2015 03:31 PM
Maxboy23
Aug 20, 2015 09:33 AM
Tommy6905
Aug 14, 2015 11:54 AM
