Front strut bar install??
Old Jun 30, 2005 | 05:59 AM
zax 20th ae's Avatar
Should i jack the front of the car up(the whole front end),
and then put my strut bar on then tighten it before lowering back down?
A friend advised i do this...
or is that a no good for a max????
Old Jun 30, 2005 | 07:57 AM
Hey thanks guys appreciate the info..........
Old Jun 30, 2005 | 08:32 AM
dennisuello's Avatar
why? just put it on and then tighten the nuts to spec.
Old Jun 30, 2005 | 08:39 AM
frankd121's Avatar
no, you don't need to raise the car up. just bolt it on.
Old Jun 30, 2005 | 08:40 AM
GreenSeMax's Avatar
there is a right and a wrong way.....it's prolly posted all over too so i may get flamed for assting here but..................put the ends on the studs first, then attach the crossbar.........put nuts on snug........SNUG.....then spread the bar two or three turns, to preload the bar.......then torque to specs.
Old Jun 30, 2005 | 08:42 AM
Puppetmaster's Avatar
Bolt it on w/o jacking... make sure you don't overtorque the upper strut mount nuts... 39-54 N-m is about right...
Old Jun 30, 2005 | 09:57 AM
Thanks guys , peppetmaster whats 39-54 n-m the n-m stands for??
Old Jun 30, 2005 | 10:04 AM
LA02MAX's Avatar
newton/meter...it's a unit that measures torque other than ft/lbs. if you have a torque wrench, look at it and the units will most likely be in N-m, however there are many that have several types of units on them....
Old Jun 30, 2005 | 02:04 PM
Thanks guys , pUppetmaster whats 39-54 n-m the n-m stands for??
Like he said ^^
Conversion is as follows: (N-m)*.7376 = Lbs Ft
So 50 N-m = 36.88 Lbs Ft
http://www.convert-me.com/en/convert/torque
Old Jul 1, 2005 | 06:29 AM
Thanks that helped thanks
kingw323
20
Oct 21, 2015 08:36 AM
homeyclaus
Sep 3, 2015 06:15 PM
MaxStock
Aug 14, 2015 10:01 PM
Greenmaxspeed
Aug 8, 2015 12:39 PM
laparka66
Aug 6, 2015 09:36 AM
