105 octane?
Old Jul 5, 2005 | 10:59 AM
RacertilTheEnd's Avatar
105 octane?
I just have a quick question about 105 octane? Will it hurt our engines? It is unleaded, but I don't know if it is safe to use. I know one of my friends uses it on his 350z and the VQ30 and the VQ35 share the same block, but is it safe? I'm rambling, I just need to know before I start selling the stuff to people.
Old Jul 5, 2005 | 11:09 AM
OOmaxSE's Avatar
as far as i know, unleaded is safe. our cars say to use unleaded only (premium)
Old Jul 5, 2005 | 11:12 AM
ok, but I know the higher the octane, the higher the internal temp. I don't want to sell it to someone and have them sue me because they melted their internals. I'm kinda paranoid. I want to buy some and test it so I can have first hand experience with it, however, I am kinda iffy about screwin up my engine. Any one use 105 before in the max?
NmexMAX's Avatar
dot dot dot ...
Waste of money though ..... 93 is fine for our cars, 90-91 for higher altitudes or California... So to answer your question it is safe, so start selling. The 350z has higher compression than your 2000, and SCC did a dyno comparison using 91 and 93 I believe, and saw an increase of 5-8whp on a 350z. .. Food for thought, but you don't have the 3.5L.
Old Jul 5, 2005 | 11:15 AM
Now what about a turbocharged/ supercharged application?
Old Jul 5, 2005 | 11:20 AM
NmexMAX's Avatar
dot dot dot ...
I wouldn't know, I like my aspiration fed naturally ..
Old Jul 5, 2005 | 11:22 AM
ok...thank you for the info. On a side note, and a totally different subject. Does anyone know if there are any aftermarket cams available for the 5th gens.
Old Jul 5, 2005 | 11:24 AM
TarHeelMaxima's Avatar
105 makes your engine run cooler, better combustion. Works great with high compression setups
Old Jul 5, 2005 | 11:26 AM
NmexMAX's Avatar
dot dot dot ...
Whenever I dyno my 03, I splash a little bit in there before ....
Old Jul 5, 2005 | 11:38 AM
chris'smax's Avatar
My understanding is that the higher octane helps to reduce knock and allows you to lean out the AFR some therefore you are able to produce more power
Old Jul 5, 2005 | 01:59 PM
JoKeRz42o's Avatar
105 octane
Honestly i've tried this application ONE time but it was the best experience ever. I filled up the tank full with 105 octane @ like $5+ per gallon.(gotta love l.a. gas prices) Anyways, point being, the engine/throttle response was AMAZING. Theres no engine lag whatsoever, the second you hit the gas the car takes off. If i could afford it, i'd use it regularly. Any comments on the pros v cons would be appreciated. I've been told it doesn't have any negative side affects(true/false?)
Old Jul 5, 2005 | 03:10 PM
so 105 shouldn't harm an engine with stock internals?
Old Jul 5, 2005 | 03:20 PM
NmexMAX's Avatar
dot dot dot ...
No ........
Old Jul 5, 2005 | 03:22 PM
ok... thanks much. Any one wanna buy some race gas
Old Jul 6, 2005 | 03:11 PM
claudiusmaximas's Avatar
how much hp gain do you think it would be if you had 93 octane and added 60 points (99 octane-ish) to the car? i was at autozone today and i was readin some fuel injector cleaner and found this octane booster that raised 60 points. wonderin if it was worth it or would it do more damage than good?
Old Jul 6, 2005 | 03:13 PM
I think Import Tuner magazine talked about octane boosters, or modified magazine did. Anyways, check with them. From my understanding, octane boosters are BS. They never boost you to the numbers they claim.
Old Jul 6, 2005 | 03:24 PM
Progress's Avatar
It's business time.
I bet this would be great coupled with the timing advance.
Old Jul 6, 2005 | 03:27 PM
THT's Avatar
THT
Throbbing member
Be careful with octane boosters. IIRC, some may have additives that aren't VQ-friendly.
Old Jul 6, 2005 | 06:06 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
http://auto.howstuffworks.com/question90.htm
Old Jul 6, 2005 | 10:32 PM
sooner02r1's Avatar
Octane booster is junk. Just run 93 octane or if you want, run some 101 or 105. I don't think it is worth the extra $3/gallon, IMO.
Old Jul 6, 2005 | 11:43 PM
steven88's Avatar
Need A Light?
isn't higher octane pointless unless you have some sort of engine management to compensate for it? whether it be stand alone or piggyback.....such as a JWT ecu or Apex-i SAFCII
so if your car has the proper equipment to fine tune the ecu....wouldn't higher octane be beneficial?
Old Jul 7, 2005 | 08:07 AM
High Octane Fuel is better for higher compression vehicles, that is why it works so wonderfully on turbo/supercharged applications. You will not see a big difference in power if you have a lower compression engine. I don't think it is nescessarily a waste of money though. If you do any track racing, higher octane fuel is better for your vehicle, but you really do not have any need for it on the street. 101 octane is street legal so you pay taxes on it. 105 is not street legal so you don't pay any highway taxes, I know in CA the highay tax comes out to be $.364 ($.184 for CA, $.18 Fed). If you run 105 octane in your car, you spend less money and even if you drive it on the street, there is no way for a cop to know that you're running 105 octane.
Old Jul 7, 2005 | 08:50 AM
Bones45's Avatar
so let me get this straight.
You are concerned about getting sued by people who buy your gas, so you verify its harmless with various people on an internet message board?
I didnt know that would stand up in court.
<shakes head>
Old Jul 7, 2005 | 08:52 AM
NmexMAX's Avatar
dot dot dot ...
Fixed ....
Old Jul 7, 2005 | 10:51 AM
<shakes head>
It is more of a thing about what it will do to the VQ30 and VQ35 engines.
NmexMAX
May 23, 2016 07:38 PM
JoshG
51
Sep 21, 2015 10:41 PM
cruce91
Sep 20, 2015 10:23 AM
Slamrod
Sep 3, 2015 07:38 PM
sdotcarter
Sep 2, 2015 09:53 PM
