brakes cleaned..
Old Jul 7, 2005 | 07:22 AM
takkar's Avatar
brakes cleaned..
What all is involved in getting the brakes deglazed, cleaned and lubed. The stealer wants 95Canadian for it. Is it something I can do on my own? Any writeups for this?
Old Jul 7, 2005 | 12:13 PM
takkar's Avatar
no one has any ideas?
Old Jul 7, 2005 | 12:30 PM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
you are wasting your money if someone is charging you to clean your brakes. if you have an issue like warped rotors, low brake pads or used up brake fluid then save your money for that. cutting rotors typically costs the same as the parts for replacement.
Old Jul 7, 2005 | 12:48 PM
bladerunr's Avatar
You don't need to lube you caliper slides unless they are sticking. The only way they start to stick is if the rubber boots protecting the slide pins are ripped or torn.
If you want to de-glaze your pads something as simple as sandpaper can be used to remove pad material and apply a rough surface to the rotors. It's not as effective as turning the rotors but it's a h*ll of a lot cheaper.
Old Jul 7, 2005 | 12:52 PM
2002 Maxima SE's Avatar
FAQ/How Tos are at the top of the forum:
http://forums.maxima.org/showthread....38#post3092338
As far as cleaning/greasing. I used brake parts cleaner to get the dust off the calipers and brake grease on the back of the pads/shims.
Old Jul 8, 2005 | 04:36 AM
nicks79's Avatar
Does anyone know how much does cutting a pair of rotors comes to approximately? Just wondering?
Old Jul 8, 2005 | 05:43 AM
sloppymax's Avatar
a buddy of mine paid 75 bucks on his 4th gen at the dealer.
Apr 16, 2020 05:15 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Socalstillen
Sep 26, 2015 12:01 PM
