IAC Valve Cleaning For Smooth Idle
Old Jul 7, 2005 | 09:22 PM
traderfjp's Avatar
Seems that the IAC in one component that controls the idle on our cars. I have a problem wit high idle and would like to try cleaning this bugger but I don't have a cluse where it is? Anyone??
Old Jul 8, 2005 | 06:50 AM
Love_00_Max's Avatar
The valve is housed inside the aluminium block right behind the butterfly plate (I think in the 2K one it is made by Hitachi). You cannot clean it completely unless you bring it out and clean it...
What I did was sprayed a lot carb cleaner right thro the butterfly plate. When you try to start the car, it would crank and die, crank and die and then shoooch the cleaner is sucked into the value. Some cleaning is achieved via this method but not complete.
Hope this helps....
Old Jul 8, 2005 | 07:12 AM
traderfjp's Avatar
I just did that and now I have a high idle situation. When I do the Idle procedure the car will idle at 650 but once I shut it off and re-start the idle goes back up to 1k. I was thinking that I need to clean the IACV or that I might have damaged it by cleaning the TB.
shilov
Feb 19, 2024 09:40 PM
Mar 12, 2020 12:06 AM
BkGreen97
Apr 2, 2016 05:47 AM
DarjeelingRose
Sep 15, 2015 01:20 AM
tardrex
Sep 11, 2015 07:35 PM
