Berk Technology Intake owners, come on down!
Old Jul 10, 2005 | 10:09 AM
djsoniq's Avatar
So I plan on installing my Berk intake tonight or tomorrow on my 2k2, anyone have tips, tricks, or things to look out for during the install? Any problems?? Thanks!
Old Jul 10, 2005 | 10:30 AM
tdogg169's Avatar
Great choose!! If you got the K&N air filter, don't put oil on it. It comes pre-oiled. I messed up my air flow meter like that.
Old Jul 10, 2005 | 10:48 AM
Puppetmaster's Avatar
It will be easy... the hardest part is stretching the couplers over the throttle body and over the MAF housing.... apart from that, it shouldn't be too hard.
Some people worry about too much vibration around the MAF and housing, which apparently contributes to MAF failure, so ya could get some rubber washers and stick em around the intake bracket to reduce some vibration from the chassis of the car.
Old Jul 10, 2005 | 11:04 AM
djsoniq's Avatar
Thanks for the idea puppet... I'm not quite sure what you mean but I'll figure it out once I have it all apart. About how long does it take to install?
Old Jul 10, 2005 | 11:26 AM
n3985's Avatar
大陆弟弟
Please post pics when done, I'm ordering my Berk intake too!
Old Jul 10, 2005 | 11:59 AM
MacAlert's Avatar
Install shouldn't take more then 15min if you can get those darn couplers on.
Old Jul 10, 2005 | 12:06 PM
djsoniq's Avatar
Sweet, I'm def doing it tonight while I have the garage and the tools...
Old Jul 10, 2005 | 12:16 PM
wngan9447's Avatar
Chicken Feet Croo!
About 10mins to get pretty much the stock items off and about another 10 mins to get everything from throttle body to Maf housing... and lastly about 2 hours to get the DAMN coupler over the MAF adapter...I'm talking about using the microwave to soften the coupler, hair dryer to keep it hot while installing and a timely filing job on the edges.. but it was worth for the great, deep growl..
Tips:
Put some white lube on the adapter, microwave the coupler and if needed take a file to the edge of the adapter
Lastly, clean out the inside of the adapter/coupler part before installing.. wipe it down with a dry cloth.. our MAFS are weak...
My install was for a 2k..hopefully your 2k2 will be easier
Old Jul 10, 2005 | 12:17 PM
Park2670's Avatar
The Ultimate Driving Machine
I know that the intake issue is a big thing here.... I just wanted a little better sound, so from what ive heard frankencar and berk have WAI for best sound and a little better breathing. Any CAI that will improve both that you can recommend? Or are the improvements so minimal I should just stick with WAI
Old Jul 10, 2005 | 01:25 PM
MdniteDrftr's Avatar
While we're on the topic, if I take the rest of the stock airbox off, what do I do with the sensor on it?
http://img.photobucket.com/albums/v3...tr/berk002.jpg (big pic)
Old Jul 10, 2005 | 02:55 PM
djsoniq's Avatar
Ok so I'm looking for an install write up. I think I'll be ok doing this, but a write up with pics wouldn't hurt. I found one for the Injen CAI in the stickies, and I can use the beginning of that, but if anyone knows of a full write up for the Berk let me know!
Old Jul 10, 2005 | 03:29 PM
n3985's Avatar
大陆弟弟
I have the instructions for the Frankencar, which I believe is the samething.
http://portfolio.iu.edu/nayang/stage2inst.pdf
Old Jul 10, 2005 | 03:38 PM
MacAlert's Avatar
Installing Injen, Frankencar, Berk are all the same (pretty much).
Old Jul 10, 2005 | 03:40 PM
NYPD-Arnold's Avatar
Z
Some people have said to NOT install the little baby (breather) filter as it creates havoc with the 5th gens IAC (idle air control)?
Old Jul 10, 2005 | 03:57 PM
djsoniq's Avatar
Thanks n3985, that looks like it will be EXTREMELY helpful. Can't wait to be done with work so I can get this thing installed!!
Old Jul 10, 2005 | 07:16 PM
chr0nos's Avatar
do the idle air volume learning procedure, in the stickies, if your rpms are not close to 650. for injen owners, you can use a small amount of vaseline or some sort of thick grease to get the rubber couplings onto the metal parts. i fought with my (now replaced) injen intake for 10 minutes, and my dad gave me this idea. worked like a charm with a small amount of grease.
Old Jul 10, 2005 | 08:20 PM
Andrew's Avatar
Djsoniq,
I left that part there because I would hope air would go to the intake that way. I took it off originally and left the sensor behind the battery but my friend convinced me to put it back just so that the air could get to the intake. I have no clue or what would make any sense in that matter but I left it there. Yeah, looks stupid but its ok.
Andrew
Old Jul 10, 2005 | 08:26 PM
Andrew's Avatar
sorry for the huge pic..
Old Jul 10, 2005 | 08:31 PM
n3985's Avatar
大陆弟弟
Thanks!
Old Jul 11, 2005 | 09:26 AM
djsoniq's Avatar
Ok so I got the intake installed this morning. I had to go out and get 4 stainless steel bolts and nuts to connect the MAF to the adapter as the used intake I bought didn't have them (no big deal, stainless is better anyways). Got everything hooked up. Now here is a question. See Andrew's picture above? He has the large vac line and two smaller ones. I only had the one big vac line, but ports for the other two, so I looped a small piece of rubber line to keep the vac in check. Are there vac lines in an 02 that I'm just missing??
Also I gotta say the thing sounds mean as hell when you floor it. There is a slight hiss though, kinda like a turbo. Is that normal? I checked all the connections and they're all solid, and if there was any kind of leak I'm sure the SES light would come on right?
Anyways I love the way it looks and sounds, def worth the money. I'm working on getting pics up for you guys, but PhotoBucket is driving me nuts today...
Old Jul 11, 2005 | 09:34 AM
ChromeSE5's Avatar
andrew has a 3.0 which has 3 vacuum lines... so you have nothing to worry about.
Old Jul 11, 2005 | 10:12 AM
djsoniq's Avatar
Awesome, thanks Chrome!
Old Jul 11, 2005 | 10:14 AM
wngan9447's Avatar
Chicken Feet Croo!
You get the hiss when you let go of the gas right? I get the same thing with my apexi filter... i like the hiss..
Old Jul 11, 2005 | 10:28 AM
djsoniq's Avatar
I like this hiss too, don't get me wrong, I just wanted to make sure it was suposed to be there!
Old Jul 11, 2005 | 11:29 AM
steven88's Avatar
Need A Light?
don't worry...its suppose to be there....also when u turn off the car....the hiss will be alot more apparent...mine gives off a real big hiss right when i turn off my car
Old Jul 11, 2005 | 11:32 AM
Andrew's Avatar
Congrats man!!! now just don't spend too much money on gas...go easy on the pedal. I wasted 3 fill-ups just to hear the engine growl!
Old Jul 11, 2005 | 07:01 PM
djsoniq's Avatar
Here ya go Maxima fans, my completed (for now) engine bay... Berk Intake, EB Sports FSTB, and painted engine cover...
Old Jul 11, 2005 | 07:04 PM
Andrew's Avatar
congrats! Looks nice
Old Jul 11, 2005 | 07:12 PM
n3985's Avatar
大陆弟弟
Painted engine cover? Doesn't the stock one look like that though? And congrats on the intake, still waiting to order mine.
Old Jul 11, 2005 | 07:19 PM
tothemax319's Avatar
The engine color is painted sunlit sand to match his body color I believe, stock color is grey.
Old Jul 11, 2005 | 07:21 PM
n3985's Avatar
大陆弟弟
OO...it looked silver to me at first. Nevermind...sorry haha
Old Jul 11, 2005 | 07:24 PM
steven88's Avatar
Need A Light?
Yup..that sunlit sand engine cover flows nicely with the body
Old Jul 11, 2005 | 07:32 PM
MacAlert's Avatar
You should have turned the midpipe around. The way you have it, the breather tube will come into contact with the engine cover. Flip it around so the side with the less material is closer to the MAF tube.
Old Jul 12, 2005 | 01:03 PM
djsoniq's Avatar
It was setup like that when I got it, used, but it's fine. I've checked all the clearances...
And yes the engine cover is painted to match the body, I realized later that its hard to tell in this pic.
Old Apr 12, 2007 | 05:26 PM
Trurida18's Avatar
this is an old thread YES...but i just ordered my Berk Intake and im wondering if i should have gotten the Apexi filter with it....i just got the standard AEM filter with it
Should i have ordered the Apexi filter?
http://forums.maxima.org/showthread.php?t=518067
Old Apr 12, 2007 | 05:27 PM
NmexMAX's Avatar
dot dot dot ...
A little late now, isn't it?
Old Apr 12, 2007 | 05:59 PM
SoonerFan's Avatar
Cletus
so you felt the need to bump this thread to ask the question...THEN START A NEW THREAD?
Old Apr 12, 2007 | 06:00 PM
NmexMAX's Avatar
dot dot dot ...
Sure seems that way.
Old Apr 12, 2007 | 06:01 PM
SoonerFan's Avatar
Cletus
i hope he someone finds the answer
Old Apr 12, 2007 | 07:44 PM
Trurida18's Avatar
WELL based on what knowledge you gain by looking at the computer screen....whether the monitor be LCD, CRT, OR DLP ....YOU ANSWERED YOUR OWN QUESTION
