Major Evap Leak
Old Jul 13, 2005 | 08:46 AM
GBAUER's Avatar
Major Evap Leak
Got an SES earlier and stopped by Autozone. I didn't get the exact code number, but it was reading a major evap leak. I had the same code about a month ago and thought it was the gas cap. Regardless, I checked all the hoses under the hood and couldn't find anything. At the time I thought it may have been a fluke, but now I think there's a real problem. Anyone else run into this? Any ideas on where to begin to look?
Old Jul 13, 2005 | 08:53 AM
Sammzway's Avatar
What exactly is the CEL code that autozone pulled for you? I can do a search for you with the exact code other then that, here's what i found for you with the information you've provided.
http://forums.maxima.org/showthread....ight=evap+leak
Old Jul 13, 2005 | 09:04 AM
GBAUER's Avatar
Thanks. I read through all of them. Gas cap is fine. I'll check the evap canister and selenoid valve this weekend.
Old Jul 13, 2005 | 09:05 AM
Sammzway's Avatar
No problemo, but I can try to pull up more information for you if you can get me the code..
Old Jul 13, 2005 | 04:33 PM
sosick's Avatar
i got the gode p0447 at autozone and the dealer told me i needed to pay them six hundred bucks.
Old Jul 13, 2005 | 06:49 PM
Bensmax00's Avatar
hey dud check your gas cap--9 times outta 10 a major evap(evap gross leak on consult) it is a gas cap---you can check the cap--tighten replace what ever--and the light should go off after awhile--or after checking the cap--have the code erased---if it isnt the cap the lite will come back on.
Old Jul 13, 2005 | 06:51 PM
Bensmax00's Avatar
For What??? it all depends on how many hours it takes them to diagnose the issue & how much they charge an hour---at my dealer we charge 105 an hour and it should only take 1 hour to diagnose and fix this issue unless it needs parts---are they going to replace your gas tank or what??
Old Jul 13, 2005 | 07:05 PM
Epacy's Avatar
Unsuccesful STL Coordinator
You shouldn't act all pissed if you don't know what you are saying.
Old Jul 13, 2005 | 08:39 PM
Bensmax00's Avatar
i wasnt pissed I was just asking a question---just sounds like the dealer was rippin someone a new one or they saw you comming--if the techs are nissan trained then it shouldnt take that long to diagnose an evap leak---and I am not saying that I am the greatest tech that ever lived---I am just saying that 600 dollars for an evap code--BS
Old Jul 14, 2005 | 06:06 AM
Sammzway's Avatar
I guess we need more generous techs like you in NYC.
Old Jul 14, 2005 | 08:44 AM
E55AMG2's Avatar
Wat
The 4 times I had that code pop up, the only thing that solved it was cutting the tie strap off of the gas cap, then removing it from around the filler neck.
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
tseng1023
Oct 15, 2015 08:30 AM
homeofbacon
Sep 23, 2015 07:17 PM
dcam0326
Sep 7, 2015 07:26 AM
