Dumb question...removing engine cover
Old Jul 20, 2005 | 09:50 AM
NJ Devils Fan's Avatar
What should I use to remove the engine cover? Allen wrench? I tried a screw driver(flathead) and started to strip one of the screws, so I stopped immediatly. Maybe a little bit of wd 40 on them might help?
Old Jul 20, 2005 | 09:53 AM
Teufelhunden's Avatar
allen wrench
Old Jul 20, 2005 | 10:29 AM
Ephraim's Avatar
if they are that tight, PB Blaster fluid will get the job done as far as getting a bolt loose
Old Jul 20, 2005 | 02:43 PM
bugbite77's Avatar
your not havin 2 much luck with screws lately are you, 1st your intake and now this, lol i feel for you brother.
Old Jul 20, 2005 | 02:56 PM
sooner02r1's Avatar
Flat head screwdriver!!!! Stick an allen wrench in that bad boy and turn it. Lefty loosey, righty tighty.
Old Jul 20, 2005 | 03:00 PM
Metal Maxima's Avatar
SHIFT_om nom nom nom
If you find that the bolts are too tight, simply slip a small pipe over the end of the allen key you are turning so that you can distance yourself from the bolt and apply more torque with less effort. Just a helpful hint.
Old Jul 20, 2005 | 11:02 PM
Hahaha, yea, damn screws, too many of them. I'm still confused at how easy that one from my intake broke, too easy.
I've used a flat head screwdriver many times when I didn't have an allen wrench handy, work almost all of them. Obviously not this time. Wonder why they made it so you couldn't use a socket wrench.
Old Jul 21, 2005 | 06:30 AM
NmexMAX's Avatar
dot dot dot ...
Why dont you use what you're supposed to use ... an Allen head wrench
Old Jul 21, 2005 | 07:43 AM
cmoore135's Avatar
YOU CAN BUY AN ALLEN SOCKET AND GIVE IT A GO. I USE THEM AT WORK ALL THE TIME SO THEY DO EXSIST
Old Jul 21, 2005 | 07:45 AM
Obviously I didn't have one around so I tried figuring it would work. Not a big deal.
Old Jul 21, 2005 | 08:32 AM
Maxi113's Avatar
If that doesn't work try a rock..Hey it works for Homer haha =0
Mar 12, 2020 12:06 AM
Max139617
Sep 20, 2015 07:25 PM
Max139617
Sep 20, 2015 07:09 PM
tardrex
Sep 11, 2015 07:35 PM
jfl330
Sep 4, 2015 01:44 PM
