sway bar bracket bent. what to do?!
Old Jul 21, 2005 | 11:07 AM
DJ2Max's Avatar
on one of the brackets that holds the bar longitudinally to the car, the lower flat conecting pies is bent for some odd reason, kinda like a fold in the corner. SHould i worry about it? anyone else ever had this problem befores? its wierd because its the only part thats bent, the other corners are fine.
Old Jul 21, 2005 | 11:32 AM
Progress's Avatar
It's business time.
Which bar do you have?
Old Jul 21, 2005 | 12:16 PM
DJ2Max's Avatar
oops, i have the addco. its the flat piece which connects the hoop piece to the axle"?" which is bent in the corner.
Old Jul 21, 2005 | 12:39 PM
Progress's Avatar
It's business time.
OK, so it is the bracket that attaches the u-bolt to the axle. Have you tried installing it and seeing if the bend interferes with the install? Pics might help as well.
Old Jul 21, 2005 | 12:44 PM
kcowden's Avatar
Pull it off and take a hammer to it on an anvil and straighten it out. Shouldn't hurt anything. Just be more careful driving over any curbs in the future.
Old Jul 21, 2005 | 12:46 PM
Progress's Avatar
It's business time.
When I torqued my nuts the brackets started to bend onto the beam so I'd imagine if his bend isn't significant it may just work it's way out during the install.
Old Jul 21, 2005 | 01:26 PM
igzy's Avatar
I Know Kwaliti
Happened to me too when installing that I slightly bent the bracket while torquing it over the trailing arm beam. I have it on for more than 10K now with no probs...
Apr 16, 2020 05:15 AM
Calabar
Oct 5, 2015 09:57 PM
gman214
Sep 25, 2015 03:03 PM
zzznightmarezz
Sep 21, 2015 06:32 PM
