which wire for the LED alarm
Old Jul 22, 2005 | 06:37 AM
merovi's Avatar
I am going to add an LED to blink while the little alarm LED by the clock blinks. I am not sure which wire to use. The write up in the FAQS is for a scanner which has 2 connections so I am nnot sure between the 2. Anyone know which wire supplies the power to the LED to blink?
Old Jul 22, 2005 | 08:36 AM
Igor911's Avatar
you need both of those wires. + is positive the other is -. Use the writeup
Old Jul 22, 2005 | 11:50 AM
K Pazzo 6's Avatar
what he said...i like those rims u got on now...
Old Jul 22, 2005 | 02:43 PM
merovi's Avatar
ok i read the write up and it says that there is a red and yellow wire, and he grounded the unit somewhere in the sunroof. I have had a scanner with my other car and know that 1 is to save the setting, kind of like the always running clock time, and one is to power it when it is necessary. thats why there is 2 wires. so 1 of the wires he is connecting to is for the clock and 1 is for the power. anyone know which is which?
Old Jul 22, 2005 | 03:05 PM
Igor911's Avatar
yellow is constant 12v, then you want red.
Old Jul 22, 2005 | 04:27 PM
MIXXMAX's Avatar
Are you talking about adding another LED in addition to the clock alarm LED, both blinking at the same time? If so, I did this and put a LED in one of the blank spots in the dash near the steering wheel. Here are the wiring codes for my 2K SE. I'm assuming you have the same year.
Yellow/Red tracer=Battery
Green/Orange tracer=Smart entrance control unit
Purple=Ignition
Red/Blue=Illumination
Black=Ground
Tap the LED in the yellow/red wire and the green/orange wire.
Old Jul 22, 2005 | 06:07 PM
Igor911's Avatar
Also, I suggest you use a relay
Old Jul 22, 2005 | 09:29 PM
merovi's Avatar
the LED only has 2 leads. + and -
- goes to ground and + goes to which?
Old Jul 22, 2005 | 09:30 PM
merovi's Avatar
i'm not to sure what a relay does but why would i want to use it? if there is a wire that controls when the LED gets connection and when it doesn't, why wouldn't i just tap that 1 wire?
Old Jul 23, 2005 | 02:40 AM
MIXXMAX's Avatar
You don't need a relay. It's only an LED, which only draws milliamps of power. Tap the positive side of the LED to the yellow/red wire and the negative side of the LED to the green/orange.
Old Jul 23, 2005 | 06:20 AM
merovi's Avatar
thank you! I'm going to go at it when i get out of work.
Old Jul 23, 2005 | 12:45 PM
ZIPPIN's Avatar
Mauja He Mauja
now that is one shiney biatch
trsandrew
Apr 8, 2016 06:45 PM
doctorpullit
Mar 29, 2016 11:08 AM
mpbclutch33
Dec 26, 2015 11:11 AM
trsandrew
Oct 25, 2015 02:47 PM
